Utility Trailer - What type of design worked best for you.
   / Utility Trailer - What type of design worked best for you. #31
Those of you with heavy trailers (10,000# +) that are bumper pull, do you use a load equalizing hitch?
Mine is behind a 6500 truck so no, but I’d think you’d need one behind a pickup. Really a bumper pull is a lousy choice behind a pickup at that weight or more.
   / Utility Trailer - What type of design worked best for you. #32
sometimes. depends how far i'm going and if the trailer can accept one
   / Utility Trailer - What type of design worked best for you. #33
No, and I haven't seen the need for anything "I" pull...
To the original question of this thread:
I have numerous trailers, including an Alumina and I really like it!
Being so light, it's really handy and easy to move around when unhooked. It's just easy to pull and I don't have the maintenance of a wood deck trailer... Really like the fold up ramp too...
I also have a PJ trailer that I use to pull a tractor to rotavating jobs, it has been a great trailer too.,
Personally, I think you will like an aluminum trailer for your purpose...
SR
   / Utility Trailer - What type of design worked best for you. #34
I NEVER trailer off property. So I built a farm wagon. It's got brand new Horst ten ton running gear - Uber heavy main beams - 2x8 removable side walls - 5/4 exterior grade plywood deck.
   / Utility Trailer - What type of design worked best for you. #35
I bought the optional spring for the tongue on mine...
It was waaaaay well worth what it cost, to keep the tongue up off the ground and make it easier to lift.
SR
   / Utility Trailer - What type of design worked best for you. #36
In the picture the tongue sits on an empty one gallon paint can. However - getting it on the drawbar and lined up - a completely WEIGHTY matter. One thing is very certain - I'm never going to hurt that tongue.
   / Utility Trailer - What type of design worked best for you. #37
I have 3 BP trailers that are over 10K. A 22' PJ full tilt bed, a 16' Cross Country dump trailer and a 32' travel trailer. I use an equalizer hitch on the travel trailer and dump trailer but not on the tilt bed. I tow with a 3/4T Chevy crew cab, 4x4, reg box.
   / Utility Trailer - What type of design worked best for you. #38
Mine is behind a 6500 truck so no, but I壇 think you壇 need one behind a pickup. Really a bumper pull is a lousy choice behind a pickup at that weight or more.
I mostly agree with that. I'm thinking about a dump trailer and they can be had in 14,000# deckover in either bumper pull or gooseneck. The bumper pull is cheaper, BUT I agree, it seems it should be gooseneck for that kind of weight, especially for a pickup truck.
Note: I do have an 11,000# bumper pull RV w/ weight distribution and I don't have a problem with it. Add 3,000# and I'd be up to the 14,000# dump. But ... I have to think on this some more.
   / Utility Trailer - What type of design worked best for you. #39
Are you towing with a SRW truck or a dually? SRW I’d definitely recommend a GN. Even then if I had to move move a 14k load on my bumper pull trailer it would go behind my 6500 not my ton truck. And a GN is a lot more forgiving with weight distribution.
   / Utility Trailer - What type of design worked best for you. #40
Try and find you a tongue off a gravity flow wagon, they make some that have a mechanism that you can extend the tongue to hook it up then you back up and it locks and off you go. We had two when we were messing with corn and they are time savers and easy to hook up.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A58374)
KNOW BEFORE YOU...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
2024 Timpte 40ft Hopper (A56435)
2024 Timpte 40ft...
1000 GALLON ALUMINUM TANK (A52708)
1000 GALLON...
Felco Digging Tooth Bucket with Soil Compactor Excavator Attachment (A55973)
Felco Digging...
Self Leveling Rotary Laser (Survey Equipment & Grade Control) (New/Unused) (A59225)
Self Leveling...
