Mower storage
   / Mower storage #11
You wouldn't even need the welding, threads, nuts or paint. Drill 5 holes in the rod, 1 inside and outside each wheel for keeper pins and 1 for the deck alignment pin. Paint? Ha!!
But again, all these implement dollies only work if you have a clean, smooth, paved floor. They won't roll worth spit over dirt, gravel, grassy areas or anything uneven or unlevel. Which means I can't use any of them.
I roll mine out into the yard over gravel and uneven terrain pretty easily. The large wheels make it a lot more manageable than even I expected. Turning is a b1tch, though.
   / Mower storage #12
Trouble is I can't find any wheels with 1" bore. Most are 1/2 or 5/8".
   / Mower storage #13
A 5/8" rod will fit inside a 1/2" pipe (with a little hammer work or a light grind of the rod surface). The OD of 1/2" pipe is about 1/8" under 1" so it will work as the axle. That's what I did for mine although I did weld the 5/8 rod to the pipe.
   / Mower storage #14
... They won't roll worth spit over dirt, gravel, grassy areas or anything uneven or unlevel. Which means I can't use any of them.
Why not? Couldn't you just swap those hard wagon wheels for 10 or 12" pneumatic or no-flats?
   / Mower storage #15
Maybe, but with the weight and size of these decks, you have to go fairly wide for any real stability. Then you end up taking more floor/ground space while stored.
Last Winter, I just offloaded mine against a fence and used a short rope to stand it up and tie it off.
2015 Komatsu PC138 (A47477)
2015 Komatsu PC138...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2025 Newrick JC25 Mini Wheel Loader Skid Steer (A55851)
2025 Newrick JC25...
UNUSED SDLANCH SDLJC HIGH-END MOBILE JAW CRUSHER (A57192)
UNUSED SDLANCH...
2001 F-150 XL SINGLE CAB TRUCK (A57192)
2001 F-150 XL...
UNUSED FUTURE CLG72 72" HYD CURVED LOG GRABBER (A57193)
UNUSED FUTURE...
