Mower storage
   / Mower storage #11
You wouldn't even need the welding, threads, nuts or paint. Drill 5 holes in the rod, 1 inside and outside each wheel for keeper pins and 1 for the deck alignment pin. Paint? Ha!!
But again, all these implement dollies only work if you have a clean, smooth, paved floor. They won't roll worth spit over dirt, gravel, grassy areas or anything uneven or unlevel. Which means I can't use any of them.
I roll mine out into the yard over gravel and uneven terrain pretty easily. The large wheels make it a lot more manageable than even I expected. Turning is a b1tch, though.
   / Mower storage #12
Trouble is I can't find any wheels with 1" bore. Most are 1/2 or 5/8".
   / Mower storage #13
A 5/8" rod will fit inside a 1/2" pipe (with a little hammer work or a light grind of the rod surface). The OD of 1/2" pipe is about 1/8" under 1" so it will work as the axle. That's what I did for mine although I did weld the 5/8 rod to the pipe.
   / Mower storage #14
... They won't roll worth spit over dirt, gravel, grassy areas or anything uneven or unlevel. Which means I can't use any of them.
Why not? Couldn't you just swap those hard wagon wheels for 10 or 12" pneumatic or no-flats?
   / Mower storage #15
Maybe, but with the weight and size of these decks, you have to go fairly wide for any real stability. Then you end up taking more floor/ground space while stored.
Last Winter, I just offloaded mine against a fence and used a short rope to stand it up and tie it off.
Hyundai HL 960 Wheel Loader (A56857)
Hyundai HL 960...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2017 BOBCAT T650 SKID STEER (A52707)
2017 BOBCAT T650...
UNUSED FUTURE 24" CAT 305 EXCAVATOR BUCKET (A57193)
UNUSED FUTURE 24"...
2006 International 4300 2,000 Gallon Fuel Truck (A55852)
2006 International...
AGT SAII100 SKID STEER QUICK ATTACH 48" (A57193)
AGT SAII100 SKID...
