AR Rifles..
   / AR Rifles.. #392
   / AR Rifles.. #393
I just watched this video on a better faster way to reload a shotgun but looks like its only in 12 gauge, everything is 12 gauge, talk about fast reload...........
Shotgun Speed Reloading! 3.5 seconds for 8 shots with reload in SlowMo (6P) - YouTube
I was picking up my .410 from the gunshop the owner was telling about somebody who (supposedly) can get a triple on ducks with a single shot shotgun.
Or maybe you should just pick up one of these. BFR .410 Results :D
   / AR Rifles.. #394
What is the purpose of the long tube under the barrel?
I know it is not to hold shells,, my gun holds 9, and the under tube does not extend past the 16.5 inch barrel,,,
Is it some sort of stabilizing assist? :eek:
1:00 to 1:05 "this one is set up to hold 17 rounds"
Bruce
   / AR Rifles.. #395
it holds extra shells just like a Marlin 22
   / AR Rifles.. #396
   / AR Rifles.. #397
More rounds for competition shooting, sort of impractical for duck hunting and slightly illegal.........
   / AR Rifles.. #398
And I caught 50 lb trout........... Probably the ducks was sitting targets.......... 410 pistol isn't rapid fire but I wouldn't mine having one. Pellatizing Clays with Magnum Research BFR .45LC/.41 - YouTube
I guess that for certain applications it would be useful, but I’ll stick with my .22. I’ve put more birds on the table with my various .22 handguns over the years than with every shotgun I’ve ever owned. I had a Contender with the .410 barrel. One December the birds were all up in the tops of the poplars and that gun was useless. I went back to the truck, grabbed my MarkII and brought home my supper.
   / AR Rifles.. #399
for competition shooting it helps stop muzzle rise from the added weight on the front.
   / AR Rifles.. #400
Do I have to "clean" a new AR lower?
I just got my first ever lower, it came from Palmetto State Armory,,
Do I just install the upper, and run it, or is there some procedure needed to make it usable?
The upper is coming later this week, I guess I will clean the bore, and spray the BCG with cleaner,, then some lube,,
Is there "best" lube for a BCG?? :confused:
My other AR was purchased used, so I just brought it home and run it,,
so I am kinda at a loss as what to do with the new plinker,,,:dance1:
2012 New Holland BR7070 Round Baler with XtraSweep and Net Wrap (A55218)
2012 New Holland...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
UNUSED SDLANCH SDLC2030FT ALL STEEL CARPORT (A54757)
UNUSED SDLANCH...
2011 NISSAN FRONTIER EXTENDED CAB TRUCK (A51247)
2011 NISSAN...
2015 Ford Transit 150 Cargo Van (A53422)
2015 Ford Transit...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
