AR Rifles..
   / AR Rifles.. #392
   / AR Rifles.. #393
I just watched this video on a better faster way to reload a shotgun but looks like its only in 12 gauge, everything is 12 gauge, talk about fast reload...........
Shotgun Speed Reloading! 3.5 seconds for 8 shots with reload in SlowMo (6P) - YouTube
I was picking up my .410 from the gunshop the owner was telling about somebody who (supposedly) can get a triple on ducks with a single shot shotgun.
Or maybe you should just pick up one of these. BFR .410 Results :D
   / AR Rifles.. #394
What is the purpose of the long tube under the barrel?
I know it is not to hold shells,, my gun holds 9, and the under tube does not extend past the 16.5 inch barrel,,,
Is it some sort of stabilizing assist? :eek:
1:00 to 1:05 "this one is set up to hold 17 rounds"
Bruce
   / AR Rifles.. #395
it holds extra shells just like a Marlin 22
   / AR Rifles.. #396
   / AR Rifles.. #397
More rounds for competition shooting, sort of impractical for duck hunting and slightly illegal.........
   / AR Rifles.. #398
And I caught 50 lb trout........... Probably the ducks was sitting targets.......... 410 pistol isn't rapid fire but I wouldn't mine having one. Pellatizing Clays with Magnum Research BFR .45LC/.41 - YouTube
I guess that for certain applications it would be useful, but I’ll stick with my .22. I’ve put more birds on the table with my various .22 handguns over the years than with every shotgun I’ve ever owned. I had a Contender with the .410 barrel. One December the birds were all up in the tops of the poplars and that gun was useless. I went back to the truck, grabbed my MarkII and brought home my supper.
   / AR Rifles.. #399
for competition shooting it helps stop muzzle rise from the added weight on the front.
   / AR Rifles.. #400
Do I have to "clean" a new AR lower?
I just got my first ever lower, it came from Palmetto State Armory,,
Do I just install the upper, and run it, or is there some procedure needed to make it usable?
The upper is coming later this week, I guess I will clean the bore, and spray the BCG with cleaner,, then some lube,,
Is there "best" lube for a BCG?? :confused:
My other AR was purchased used, so I just brought it home and run it,,
so I am kinda at a loss as what to do with the new plinker,,,:dance1:
2004 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2004 CATERPILLAR...
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
2022 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2022 Allmand Bros...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
2016 Ford F-250 Ext. Cab Pickup Truck (A53422)
2016 Ford F-250...
