Side panel clips - where to buy, or what to use for replacement.
   / Side panel clips - where to buy, or what to use for replacement.
I don't have a clue about these clips, but could they have been Stainless Steel? And therefore not magnetic?
I think there is a bit of surface rust on some of the others, but even "stainless" should have been found by the MOJO stick that I was using.
Those things have POWERFUL magnets in them, they can be dangerous so I didn't probe around inside the tractor with it - the bit could still be lodged up inside.
   / Side panel clips - where to buy, or what to use for replacement. #12
Those spring clips can be aggravating. And they can be hard to line up when you reinstall the grills. But they have held for 15 years so I really cannot say too much. But I definitely take my time when removing and installing the grills. W Jones
   / Side panel clips - where to buy, or what to use for replacement. #13
If I look for somethong with a magnet, I hope to have another piece like I am looking for and see if it is magnetic, then go one step farther by let's say throwing it in the grass (Where I can see it) and see how much luck I have recovering it. No sense pending time on a plan that isn't going to work.
   / Side panel clips - where to buy, or what to use for replacement. #14
I bought a few a while back from Daves tractor in Ca.
No they aren't cheap, but they work good, I spray them once in a while with wd40 to keep the rust to a minimum.
If you come up with a replacement, please let us know.
Yeah, I'm familiar with that technique, however.....
with these particular clips just taking them OUT can lead to them springing apart, similarly putting a test part back in, so I am loath to sacrifice another one just to see how/where things fly, land and hide.
ANYWAY.
Today I put one of the plastic rivets in, the 1/4 inch hole one was the best fit, the 7 mm one was too fat.
Another thing I liked about the 1/4 inch hole one is the large head on it, about the size of a US quarter.
I didn't run the tractor to see if I could get it to vibrate out, I was there for other reasons including putting the wheel back on the Harley rake (new inner tube).
It will be no great hardship to have to carry a #2 Phillips head screwdriver on the tractor<grin>
When I have nothing better to do some winter's night I may take one of the clips apart, lay the tab on my scanner to get a profile of it and then print a few in ABS plastic (bicycle helmet plastic), which is good tough stuff. About 1mm thick should work.
I know, I know, I'll NEVER find one of those with a magnet.
   / Side panel clips - where to buy, or what to use for replacement. #16
Saw this thread searching for the panel clips. Found that JD part #AM102018 looks pretty close and ebay and Amazon have quite a few. Just bought set of 4 for 11.97 on amazon. Hopefully they work.
They are likely the same - given that Kukje has contract built JD cat 1 tractors ( & probably still does).
The paint, its all in the paint - green and yellow makes such a BIG difference (-:
   / Side panel clips - where to buy, or what to use for replacement. #19
Received the JD clips today and they're a perfect fit. 3 bucks apiece delivered works for me.
2016 Dodge Grand Caravan Van (A59231)
2016 Dodge Grand...
2016 Toro Sand Pro 5040 Bunker Rake (A59228)
2016 Toro Sand Pro...
1986 Ford LNT9000 Dump Truck (A56438)
1986 Ford LNT9000...
2016 Ram 4500 Chassis Ambulance (A59230)
2016 Ram 4500...
2017 Ram 1500 Pickup Truck, V6, 4X4, Automatic Transmission, 212,570 Miles (A56438)
2017 Ram 1500...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
