What lube for off Road mini bike chain
   / What lube for off Road mini bike chain
I bought two of those Coleman’s. They are a hoot to ride. I modified one with a Torque converter. I ground off the throttle limit screw on both. Very good value for the price! If you will be riding daily I would get the motorcycle spray film lube. If ur only riding on the weekend I would use chainsaw bar oil (this is what I use ).
I got mine mainly for fixing fences through the woods and checking on cattle. It seems too fast for the woods and I'm thinking of switching from the fifty to a sixty tooth sprocket to slow it down. Do you think that would work?
I just removed the chain and didn't see any O rings.
   / What lube for off Road mini bike chain #14
I think a 50 to a 60 tooth is a giant difference..probably to much... when I was racing bikes, a 2 tooth larger sprocket was a big difference.
   / What lube for off Road mini bike chain #15
From someone who has been riding dirt bikes for the past 50+ years...
If the chain on the bike has no orings, then get some chain lube specifically designed for motorcycle chains. As mentioned above, the fluid part will evaporate leaving a waxy film behind that does the lubricating but does not attract dirt as bad. Any of that other stuff - it will attract dirt and then turn into a grinding compound between the chain and sprockets.
If the chain on the bike has o rings, don't do anything. Just ride the bike. The o ring chain has lubricant sealed inside by those o rings. That's what all current dirt bikes come with these days. My current Yamaha's o ring chain has 7,000 miles on it now and never been lubed and has barely needed any adjustment.
The Yamaha on the edge of Whitmore Plateau overlooking Parashant Canyon, just north of the Grand Canyon:
Thank you. I'll see what's available.
   / What lube for off Road mini bike chain #17
If u are wanting more control at lower speeds then consider a torque converter. U will also get smoother operation going up and down hills with a torque converter.
https://www.gopowersports.com/coleman-ct200-series-torque-converter-kit/
   / What lube for off Road mini bike chain #18
I have used Belray Super Clean chain lube on my motocross bikes for years. Good stuff that dries on the chain so it doesn’t attract dirt.
   / What lube for off Road mini bike chain #19
Several years ago, I stopped by our local motorcycle shop and picked a large spray can of chain oil.
After riding motorcycles for 50 years I can say that this is THE BEST stuff money can buy.
It sprays on like WD-40 so it soaks in well.
But when it dries it leaves behind a fat film of synthetic grease that lasts and holds well.
Now, I use it for everything.
Hay baler, machine chain couplers, door hinges...
I buy 3 of the large cans at a time:
Pro Chain - FUCHS Silkolene - Superior Motorcycle Oils
   / What lube for off Road mini bike chain #20
PJ1 blue label is some really good chain lube. Sticks well to the chain and doesn't fling off. And I believe it resists collecting dust.
Rob
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
Vehicle Tow Dolly (A52377)
Vehicle Tow Dolly...
2018 Chevrolet Malibu Sedan (A53424)
2018 Chevrolet...
2003 John Deere 310SG (A47477)
2003 John Deere...
2014 Dodge Avenger Sedan (A53424)
2014 Dodge Avenger...
Adams 6 Ton Hydraulic Lime Spreader (A55301)
Adams 6 Ton...
