Skid plate for GC series tractors
   / Skid plate for GC series tractors #101
5 plus 11 other big and small batteries I need to keep charged over the winter, if I do not have a tender on them I rotate the auto chargers.
   / Skid plate for GC series tractors #102
Finished welding the tabs on for the arms on the mmm lift and cut remaining corners on the skid plate so tomorrow I will go out and heat the garage/shop up with the kerosene heater and then I will see how close my measurements are, wish I could of had the mower deck in my basement shop as I did the measurements, anyway I will see what happens tomorrow.
It was a balmy 26* here today and it is going to be the same tomorrow.
You're almost there Jim, looks like.
   / Skid plate for GC series tractors #104
Well the front tabs aligned up and fit but they where tight so I will ream both front holes out just a fraction of a hair then pin the hanger back on and put underneath and see if I measured right for the lift arms tabs and then I can adjust the plate if need be, do not know if it will hit anything underneath the tractor being I figured a flat plate would work.
20 dollar skid plate plus time and a few feet of welding wire.
   / Skid plate for GC series tractors #105
If it works I will round the tabs off with the grinder and clean it up and paint it with a undercoat of some sort. 90.00 dollar welder on a 20amp circuit woohoo....
   / Skid plate for GC series tractors #106
Someone was fluxcoring! Lol
   / Skid plate for GC series tractors #107
I don't know if I'll get to the project this winter or not. I think for mine I'll build a full length L channel frame that connects to the front and lifts at the deck pins under the user platform. Then I'll weld steel plate to the frame made of L channel with any contours cut out that are necessary for the underbody.
Nice work on your project. I like how wide it is to protect everything. Glad you could get back in the shop.
   / Skid plate for GC series tractors #108
That is a good one, never thought of that one hahaha fluxcoring. Definitely not the ideal set up but it worked kinda, I did have a few areas where I got good penetration hahaha. Should of just tacked it and let my neighbor finish it with his 220 oh well.
   / Skid plate for GC series tractors #109
I figured if the deck is acting like a skid plate now why not make something like the middle of the deck, I am a bit curious if there will be a way to get it tucked up higher if it fits, seems like the deck drops a inch or two but maybe if a person kinda holds the lift lever then turns the knob to lock the deck up it might hold it a tad higher. Guess I will answer that question when I get back out to the shop/garage.
The reason I didn’t go the L channel route was because I figured it would hold/trap a lot of dirt and stuff on top so I let it pass and then I also thought of using a perforated sheet of metal so small stuff could fall through. I think your on the right track using L channel and if mine works I might just add the L channel on the underside of it and knock those back tabs off.
It is only 25* out so I will need to warm the shop up a bit before I hang out in it, cold and blood thinners do not go hand in hand.
   / Skid plate for GC series tractors #110
I also did some fluxcoring with my Campbell Hausfield 110V last night. I rebuilt my dad's homemade 3pt towbar for his BX because he got a QH for his birthday. It does the job off a 20A circuit on anything up to 3/16" steel. It's probably what I'll use for the skid plate if I don't buy a 220V gas MIG before then.
Picture is a test fit after it was all welded up on my GC.IMG_20191030_221748.jpg
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2019 Ligchine Spiderscreed Concrete Screed (A55851)
2019 Ligchine...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
John Deere 3025E (A53317)
John Deere 3025E...
Caterpillar 12M3 (A53317)
Caterpillar 12M3...
UNUSED WOLVERINE MCB-11 48W 48" HYD 4N1 BUCKET (A57193)
UNUSED WOLVERINE...
