Diesel in winter
   / Diesel in winter #12
ruffdog- Thanks for the link :cool:
   / Diesel in winter #14
They may only start to change the blend 2 days before the forecasted low? So if you bought your fuel 3 days ago or more you’re S.O.O.L? Well that’s helpful. Not.
I have never had a problem with their fuel and I have jugs sitting around much longer than 3 days. I do use white bottle PS though.
   / Diesel in winter #15
Your adding your own additave then. The old saying goes here....if you want something done right...
   / Diesel in winter #16
Yes, this is how I understand it's done now. It's a gradual increase in mix, just a couple days prior to low temps, and they re-adjust back if warmer temps are in forecast. This is done for what diesel is mainly used for, which is trucks not tractors. It's not done at a certain date and mixed for maximum cold all winter. The dates they show are to indicate the window that they monitor cold temps and mix accordingly, one day at a time. They figure most fuel is used within a few days of when it's bought.
   / Diesel in winter #17
This is very faulty "figuring".
Even with my most driven vehicle that I take to work every day (34 mile round trip), it can take me over 10 work days (or 2 full weeks) between tank fills (360+ miles on a tank).
If it was diesel, I, and most people would be S.O.L.
Do most people fill their tanks every 2-3 days? What percentage of people do?
To claim it's "treated", while technically true, is deceptive.
   / Diesel in winter #18
After reading this thread, adding my own additives is what I will do. They are not expensive and I doubt I will use more than 50 gallons of diesel blowing snow and moving firewood during the winter. Temperatures can drop to -35*F but that has only happened once in the 6 winters I have spent here. At that temperature I would not be using the tractor but fuel will still gel. When it happened, I had a diesel truck and it died 1.5 miles from home...gelled fuel. Royal PITA.
I will double does both the PS white bottle and Clear Diesel Fuel and Tank Cleaner. Going to get some Diesel 911 as well. Better safe than sorry.
   / Diesel in winter #19
Just dose the fuel yourself for the worst case scenario and then you don't have to worry about it. Don't buy more fuel then you'll need. That's what I do and have never had a problem. Unfortunately, you can't rely on others and can't make assumptions. If you do you'll be disappointed at the worst of times. Who needs that.
DEWFPO
   / Diesel in winter #20
You will only freeze up once and thereafter always be adding your own additive at every tanking, believe me.
When your tractor stumbles and burp and your fuel bowl looks like mushy icecream its too late.
That's coagulated wax and it can't be pumped by the injector pump.
Only cure is heat at that point.
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2003 Big Tex 10PI...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
2006 International 9400i (A55302)
2006 International...
2014 Ford F-150 Pickup Truck (A55852)
2014 Ford F-150...
1987 EZGO Golf Electric Cart (A53424)
1987 EZGO Golf...
