Diesel in winter
   / Diesel in winter #41
I read a study on the lubricity of different additives and after watching project farm's video I'd like to try something different than the Power Service products. I haven't had a problem, but I like what I saw and read of the Stanadyne. It's not something I've found, but maybe I'll order some. Power Service is available everywhere around me, along with the Howe's.
   / Diesel in winter #42
With cold and maybe snow coming, I need to get some.
I do have a bottle of 911 on the shelf.
   / Diesel in winter #43
The lubricity test was done with full strength additives. I wonder if the test results would vary if done with proper dosed diesel, since sometimes the additives are made to react with the fuel.
   / Diesel in winter #44
I dont really see the addition of diesel to the additaves making the libricity tests much better than streight diesel. It would be interesting to see though.
So many good things to test on this subject. Im hoping project farm channel is reading.
   / Diesel in winter #46
A hairdryer can be a good tool, in addition to, or absence of, red bottle 911.
And enough length of power cords to reach the tractor or utilizing a portable generator.
Wifey was not happy when I burnt out her hairdryer.
   / Diesel in winter #47
Related question:
I started my MF GC 2310 yesterday and she was blowing heavy black smoke. My son told me it was because the fuel gelled. I let her run and then filled it with fresh fuel with the additive. It ran for several hours yesterday and today and at high rpm痴 the black smoke continued.
My thought is replace the fuel filter and then fresh fuel. Am I on the right track?
   / Diesel in winter #48
If it is moving and usable to be getting heavy black smoke it's getting plenty of fuel.
I'd check the air filter and associated ducts for restrictions,
is the temperature coming up to the normal range?
   / Diesel in winter #49
Is the black smoke constant? Heavy? No load at idle? How's the power feel? Normal?
Black smoke typically means an overly rich fuel to air ratio for a particular rpm. The correct air to fuel ratio for any particular rpm produces little to no visible black smoke. If you had electronically controlled injectors I would say check for a leaky injector but I believe your injection is mechanical.
Start with simple things first. It sounds like your getting plenty of fuel. As LouNY said, check for an airway blockage.
DEWFPO
   / Diesel in winter #50
Will do. It is moveable. The power is weak at the high RPMs. Critters love to nest in my equipment so I will check out the filter and ducts. The temp seems normal. The heaviest of smoke is at the high RPMs and it is HEAVY!
New Holland T2420 (A53317)
New Holland T2420...
2005 Toyota Highlander SUV (A56859)
2005 Toyota...
2018 Chevrolet Tahoe SUV (A55973)
2018 Chevrolet...
2007 JLG SKYPOWER 800AJ TELESCOPIC MANLIFT (A52707)
2007 JLG SKYPOWER...
2017 Ford Expedition SUV (A55853)
2017 Ford...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
