New to the diesel tractor world.
   / New to the diesel tractor world.
Greetings mechanic4u. Welcome to the best tractor site on the World Wide Web. :thumbsup:
First off, have you even tried to start it? If so, what are the symptoms? What color smoke coming from the exhaust, if any? Where are you located?
No, haven't herd it running. Bought, and the injector pump was off and in a box. Previous owner had it "somewhere" and was told pump as bad. Owner ordered one from China, but it was wrong one. Frustrated, he sold to me. I have one on the way from a guy in Alberta that seems to have a good supply of parts. But I have no clue on how to properly time the pump and the engine when it does arrive! I work on cars for a living, this is my first "kick at the can" for diesel tractors. I'm located in Aylesford, Nova Scotia, Canada.
Is the engine partially disassembled? Why would you be concerned with Injector pump timing? We need more information to start offering opinions about what to do.
Welcome to TBN.
Pump is off when I bought it. Was told it was bad. Got a new one on the way.
Welcome. What year and engine . I have an 2007 DF 354 with the Chang Chai engine. Straight gear no shuttle, 514 hrs. Its been a good solid tractor. I've done lots of mods. Enjoy
Post some pics when you have time.
It's a 2009. I,ll see what I can do about pics. I'm as new to computers, as I am to diesel tractors!:confused2:
   / New to the diesel tractor world. #16
Being a mechanic gives you are good start to your project...but good luck anyway. Hopefully the only major item will be the injector pump.
Just a warning on tractor operation. There are posts here on safe operation...read them. Some good (and not so good) YouTube stuff as well. If it looks dangerous it likely is so do not do it. These things can kill you. Get your tires filled. More weight adds both stability and traction.
Welcome to the forum
   / New to the diesel tractor world. #17
Pumpguy is an excellent resource and will give you solid information.
RickB is also a great source.
Between these two they'll have you timed in no time (pun intended).
That would be great. Tried to find a service manual on line for this model, but can't find hardly any info, of any sort. Thanks!
   / New to the diesel tractor world. #20
There are no service manuals for these tractors, only operator and parts, and you will be pressed to find those. You may, however, find manuals for a tractor similar to yours, like a Jinma for instance.
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
UNUSED RAYTREE RMBD50-50" DRUM MULCHER (A51248)
UNUSED RAYTREE...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
Duetz Power Unit (A50120)
Duetz Power Unit...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
