dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,043
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
I've never worked with SIP Panels, so this is really interesting to me. Did they tell you how long it would be when you ordered them? How long did they say?
Can't wait to see you installing them, that's going to be a great day!!!!
It won't be "a day". Unless you have a simple plan and an experienced crew it will take longer than that. If you are new to it, the first day will be setting a handful of panels at best. You will find out that, while it can go easy, some panels just don't want to fit together easy, even though they should. I farmed out this part of my build to Roger, a local builder that had years of experience with SIPs and general construction. He had a few "specialized" tools for the job, but nothing major. First off was a beater block. He had a 1x6 screwed to a 2x8 (8' long). This was so that the 2x8 could bear on the OSB flanges without crushing them and the 1x6 kept it in place and didn't interfere with the foam. This was used with tool #2 which was a whole new take on the BFH. He had taken an offcut from a glulam post that was like 15" square maybe 18" long and put a handle on it - like an axe handle or the like. He was looking for mass here to move things... He would have a crew member hold the beater board up in place and then whack it with the BFH to "convince" a stubborn panel to go to the home position. Think Thor's hammer... Then there is the heated foam cutter, which is a heating element that just plugs in but allows you to remove foam easily if you need to make changes. That one is best to just buy, not make, but not too pricey.
Don't forget the sealant everywhere as you go, and you will have an airtight wall system. And then install a fresh air ventilation system to control your air changes.
A bit late in the year to be framing exterior, but you are in a warmer climate. Still you will want to try to race a bit to get that dried-in before it gets too nasty. I barely made it up here when we did it, and it cost $400 a month to use a construction heater in the otherwise uninsulated shell (only the wall were SIPs) for the winter. I was putting in windows and doors in early Nov, with the roof shingled a week later, and it turned out to be a very bad winter, and an early one right after that...
Keep on plugging away!
-Dave
