6 pages in. Did I missed the fix for the radio losing reception when I turn the LED lights on?
I didn't read through all 60+ posts, but are these LED lights add-on? In their own housing...probably plastic?
Wonder how the interference would be affected if they were housed in a grounded metal box?
I'm a retired electronic technician also, not close to your expertise, but then I wonder about if a grounded metal case, what if front lens covered by metal screen wire, maybe copper screen? Also grounded and it may not affect light output much (whole thing in a Faraday cage).
Then if feedback on power line maybe isolation series diode with filter cap to ground near light?
It's great that you posted this also and all the work you're doing to solve it. Wow! This "There is over 1.6 V(p-p) RFI riding on top of the 13.8 VDC power line !"
is amazing and explains so many problems people (may) experience using LEDs.
Before retiring I was a troubleshooter, primarily consumer electronics.
The diode/cap idea was a simple isolation thought which would drop LED supply by about 0.65-0.7V (with it's smps wouldn't affect light output).
It would be more complexity but a separate battery such as an inexpensive (like Everstart 230 cca $22), LEDs powered by it, that battery then charged by isolation diode from tractor alternator.
Me...I'd be thinking of ditching LEDs in favor of halogen!
)...very simple. B+ is power source, cathode has electrolytic cap to ground, this is now source to lights.
This is a simple draw app (my finger is shaky)...very simple. B+ is power source, cathode has electrolytic cap to ground, this is now source to lights.
Of course this would be close to LED, maybe one for each. With your o-scope probe here, value of cap for lowest p-p noise level. Who knows...1,000 ufd @ 25v, a low esr hi temp quality cap?View attachment 629111
I haven't read through all the 70+ posts, but my understanding was you have an New Holland tractor that all was well. You replaced the factory halogen lights with LED lights. This created noise problems because the LED lights have their own smps which are adding that 1.6vp-p ("pulse, noise") onto DC.
Now instead of "clean" DC (except when running whatever little bit alternator pulses) you have this which affects radio, possibly computer, etc.
Isolation diode and filter cap hopefully would block this feedback from LED lights back onto tractor power line.
Am I correct?
I understand and we're on the same page.
Ok...
"The SMPS and LED's are all inside a die-cast aluminum enclosure. The issue is the SMPS contaminates (inadvertently) the 13.8 VDC supply (INPUT) voltage from the tractor."
What I'm trying to say in that simple drawing is do not supply LEDs tractor power. Instead tractor power to anode of diode. Diode cathode to LED supply.
I'd use one diode+cap each light.
Instead of 13.8v going to each LED you would have 13.1v. Scope this point. Cap value for lowest noise.
Simple...hopefully this diode/filter cap prevents feedback from LED back to tractor "B+".
I used ECG125 diodes all the time. 1000 prv, 2.5A.
