Best way to refill 1lb propane bottles
   / Best way to refill 1lb propane bottles #1
Rebeldad1
Hughett Bend Washington
Kioti Tractor, John Deere Mower,New Holland Mini Excavator
I see there is both throw away and refillable bottles available. Any advantage?
Whats the best way to fill them?
   / Best way to refill 1lb propane bottles #2
I bought an adapter at Northern Tools. I have had zero luck despite following numerous youtube videos. I hate spending money on overpriced propane bottles!
I overcame the partial filling issue by freezing the bottles and using the second valve on the tank for purging, but my latest problem was that the second valves would not reseal. So I just had to hear my valuable propane leaking slowly away.
Where do you see refillable bottles? That would interest me.
   / Best way to refill 1lb propane bottles #3
I fill them ALL the time with just the fill valve. I put the small ones in the freezer or outside in a snow bank. I put the big tank in the 90 degree basement. I heat/cool them accordingly. I then turn the big tank upside down and open the valve. Sometimes it takes several minutes. Most times I can fill them as full or a bit fuller than a new one. The fuller the big tank the better it works. If I get one that does not fill or leaks I just use it for target practice and then scrap it. I can always find the small tanks on the ice while fishing so there is n ou shortage. I tried the forceps on the relief valve etc., but the above way works the same. YMMV
   / Best way to refill 1lb propane bottles #4
I'm not trying to be Debbie downer here but overfilling a propane tank is a very bad idea. It has to be able to expand or it can explode. I took a 3 day propane class when I was in the FD and it had me scared to light my gas grill when it was over.
   / Best way to refill 1lb propane bottles #5
Yep, you can only put 80% liquid in a tank, as you need the 20% for gas.
Amazon
   / Best way to refill 1lb propane bottles #7
I filled 4 by freezing small tanks and make sure 20# tank was warm, like in the summer. I used a transfer valve from Amazon and got each tank 1/2 to 3/4 full approx. Took only a minute to fell each one. Just make sure the Schroeder valve in the small tank seats. I put a little water on top to see if it bubbles. If it does leak I connect a torch and take it off and check it again. Then sometimes I just leave the torch head on.
   / Best way to refill 1lb propane bottles #8
I once bought a refillable Propane kit and fitted to my motorhome, or as the US call it RV. to provide the cooking and heating. Once fitted it was checked by a qualified gas engineer and given a safety certificate. To fill, I would pull into a `gas` station that sold propane for vehicles, and just fill it up. There was a device in the tank to stop filling above the maximum allowed. The system had a contents gauge. If I had a need for propane now, I think I would consider buying another kit and have it so arranged I could pick it up when empty and take it too the nearest `gas` station to refill. At the time when I bought the system, I worked out the cost, and after filling the tank 4 times, it would be in profit over buying refilled cylinders from agents.
Great way th handle the valve. All single one use bottles?
   / Best way to refill 1lb propane bottles #10
Campground etiquette: When you're ready to go home and the final 1 lb cylinder from your camp stove won't seal after you detach it - offer it to a neighbor or leave it next to the dumpster, for another camper to use.
   / Best way to refill 1lb propane bottles #11
I have a couple Flame King refillable bottle. It has a bleed valve. You can buy the filler part too but I already had a setup for the disposables. On the disposables you end up reeking of propane trying to hold the reverse Schrader type valve. Some people fill them until equalized then take like a small Allen wrench and burp the main valve a few times then fill again. Repeat process until it issues liquid when held at about 45* angle and burped. That leaves room for the gas. Also you can get a small scale and weigh it so you don't overfill it.
   / Best way to refill 1lb propane bottles #12
I will never forget as a twelve year old, my Mom bought me a Bernzomatic Torch. Kind of a nice one with a pencil flame. Anyway, that was my first experience with a sticking valve, when I unscrewed the torch head. I threw it out of the garage onto the lawn. There was ice on the lawn in summer. To this day, I wonder what I did wrong to cause the valve to freeze up.
   / Best way to refill 1lb propane bottles #13
I fill all my small tanks with an adapter I bought from HF.
Put the small tanks in the freezer for a few min. Screw them onto the adapter. Turn the large tank upside down and open the valve
   / Best way to refill 1lb propane bottles #14
Did that, with a brand new BBQ tank, but never got much of a fill. And then I messed with the schrader valve looking thing, got a good fill, but it leaked until empty.
   / Best way to refill 1lb propane bottles #15
I bought one of those adapters that you use to fill small bottles and followed the directions to the T and still couldn't get it to work. Waste of money.
   / Best way to refill 1lb propane bottles #17
Really weird how half the guys do this sucessfully and the other half can't make them work. An adapter is an adapter!
The local propane guy was trying to tell me that his propane is better than the tank exchange program because HIS propane is FRESH! Maybe it's something like that! lol
About the only thing they might be able to add to their big propane tank is smell. Maybe your propane guys company uses Gain laundry fresh scent?
   / Best way to refill 1lb propane bottles #19
I like April Rain myself.
   / Best way to refill 1lb propane bottles #20
He must have a "sell by" date on the truck.
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2025 CFG Industrial QK20R Mini Excavator (A59228)
2025 CFG...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
2011 Toro Multi Pro 1250 Sprayer Cart (A59228)
2011 Toro Multi...
207283 (A52708)
207283 (A52708)
2016 Deere 180G (A60462)
2016 Deere 180G...
