/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #31
UHMWPE is tough but flexible... but for serious shaping, it needs to be heated. I used a small propane torch: just as the material BEGINS to get clear, it can easily be bent to shape... but then hold it in position for 15-20 minutes to allow it to cool. Once it's cool, it will return to its normal milky-white appearance. It really retains heat well and will definitely burn your fingers if touched too soon!
Is it due to time or is that plastic just hard to shape and attach ? Be nice not to get snow build up in the chute when done. 8-15 inches of snow expected for us between now and Saturday late afternoon plus high winds.
It's just me that any project takes 4 to 10 times longer to do.
UHMW, like irvingj said is easy to work with, I just cut it with tin snips (left and right handed aviation snips) and the radius slotted hole I drilled a hole at both ends and used a jigsaw then a file.
I heated my UHMW with an electric heat gun in one hand and a infrared thermometer gun in the other to check the temperature, once it's heated to about 160 to 180 degrees I then clamp it to the chute, let it cool and it stays to that shape.
what style tire chains did you order?
KC
(next update about this project, see post #35)
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #33
I just bought some medium duty 2 link chains off eBay for under 100 dollars for 26-12-12 tires and the reason I did it like this is I do not plan to use my 1705 for snow removal at this time but if I do take it out I do not want to get stuck having the R4 tires on back, I have read that they(the R4s)get hard in the cold and have little to no traction so chains are a must and down the road if I get a cut with a snowblower I will invest in some heavy duty v bar chains but for now I have my Polaris Ranger with heated cab and plow, the Husqvarna 48 with snowblower and a Yard King walk behind snowblower so I am covered for snow. I sit in my Ranger and my sons use the other equipment hahaha.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #34
We are in a storm now with snow accumulations of up to 12-15 inches so in the morning I will be busy. Have about 3-4 inches right now.
I will eventually look into the UHMWPE later on, would work nice on the blade to keep snow build up off it, put like a 12 inch x 60 inch piece on the blade.
ePlastics seems to have a good price on this product.
Oh man, you do have many snow removal tools in your tool box.
I thought about lining the MF 2340 Dozer Blade, but I have not used it much in 11 years, it still has most of the MF paint job on it, which is pretty slick still, and I just spray it with 2 heavy flood coats of "Super SLICK SLICK Stuff" in the summer and let it sit for a few days in between coats.
I am still working on lining the snowblower, right now I am working on the 3 fan blades and the little discharge area just below the chute.
Here are a couple more pics of my slow progress:
(next update about this project, see post #67)
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #36
My daughter and I hung Christmas lights and cleaned leaves out of the gutter.IMG_20191130_124729.jpg
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #39
What size UHMWPE half inch?
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #40
2:30am and here is my deck, it’s still snowing pretty good, think will hit the 10-12 inch mark by morning.
Westfield Conveyor (A56436)
Westfield Conveyor...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
Tank Only (A59076)
Tank Only (A59076)
2021 Deere 333G (A53317)
2021 Deere 333G...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
