Comparison KOYKER 140 LOADER for YM2610? Maybe not, what else then?
   / KOYKER 140 LOADER for YM2610? Maybe not, what else then? #11
Got lots of firewood to move at times. A rear FEL or dirt scoop would do nicely. And when moving all of those square bales.
Valspar makes a good farm paint
Thanks for the tip on paint.
I built rear forks out of bedframe angle iron plus some scrap. Matching it to the q-hitch meant I didn't have to buy 3-point pins. Then I added a platform, and later reinforced the platform using another bedframe. I use this all the time for hauling stuff around. Hitching it on takes only an instant, just back into it and lift.
If you have a welder, fabricating something like this might meet some of your needs immediately at near zero cost.
Photo 1
Photo 2
Photo 1
Photo 2
Nope, no welder here. :(
I'm good at carriage bolts and brackets. :thumbsup:
Still need something to do a little dirt moving for gardening. Also, moving wood chips too.
For a carry-all platform, I get those IBC totes with the aluminum base and the black plastic inside platform. The cage works good too. Some are free and others from $25 to $75.
I do love your photos. Your orchard work is a blessing to look at.
Some time ago, when the Yahoo Tractor Owners Club was around, the owner Jay Brown offered this as a rear 3PT FEL all for $700. Wish I was around for that back then. What a bargain!
Here is an IBC tote carry-all. Just need forks to pick up with the FEL or off the 3PT rear.
   / KOYKER 140 LOADER for YM2610? Maybe not, what else then? #14
I have a front end loader made by coldwater in hoquiam here in Washington State. They dont have a webpage and have to be called. It was about 2 years ago but this was the number: 360-533-2160. I'm happy with mine, very simple and solid with easy to replace off the shelf hydraulic cylinders if anything ever needs replacing. I'm pretty sure they will ship and I think mine was 2k installed. They do the install no extra cost. Btw, I have 2610d as well.
We have these 3 pt loaders over here, that do have some decent lift height and weight. They have a telescopic arm that you can the length by simply pulling a pin.
You can also get buckets, spikes for manure or bales, grapple, forks and a hook to use it as a crane. Since it's a single arm design vs the two arm on a front loader, the attachments are usually narrower (40" wide) than what you are used to.
PTSG, Hey, I did find this on YT. It will dig, drag and can change over to forks too. Tylny ładowacz 4 - YouTube
Now, what product is this? Price should be close to the KK dirt scoop. It loosely translates to a Kippbox.
   / KOYKER 140 LOADER for YM2610? Maybe not, what else then? #16
Looks like a homemade 3 pt loader. Almost like what I've shown, but a lot simpler and lights which is good for smaller tractors.
To Portuguese, it translates as Rear loader.
Since the video is in Eastern Europe, I'm pretty sure it's homemade. They make all kinds of stuff like this. Lots of different variations also.
It also looks like a very simple and easy design to make at home, if you happen to have the tools though.
EDIT: Tried to get on their website to see if they have a price for those but the site won't even load for me.
   / KOYKER 140 LOADER for YM2610? Maybe not, what else then? #17
That 3 pt bucket rig looks neat. If you build it yourself, work on the design and put in a couple of hydraulic cylinders and you could get some more lift than just the 3 pt lift and have the curl and dump features also.
It is still not going to do all for you that a FEL would, but probably not cost as much either.
I did a search for the Kippbox. In the EU, it ranges from a mere 399.00 Euros to 599 Euros. The cheaper with just the lever and rope for dump, the more expensive with the hydraulics. Thus, it's in tune with Jay's offering years ago with the DG Equipment type. hmmmm.
Here is the TM100HS. A mere 399.oo Euros with the hydraulics! Kippmulde TM100HS Hecklader Heckschaufel Kippbox Transportmulde hydraulisch - Motorgeräte Fritzsch GmbH
I would buy this immediately today if it was available right now in the USA! And their shipping is CHEAP for 65.oo Euros too!
   / KOYKER 140 LOADER for YM2610? Maybe not, what else then? #19
Very good prices, specially compared to US. The 65€ shipping is just for inside Germany.
You may try to send them an email asking for shipping prices for the US.
Here in Portugal those are not very common. What we use a lot is those 3 Pt loaders I showed before and probably the most sold implement here, a Carry all box.
This carry all box comes with lots features, let's see if I remember everything:
- It can dump by pushing a simple lever to unlatch the hook.
- It has a cutting edge on the rear so you can load and scrape materials
- Removable tailgate that can also flip down to extend the length or just flip up and out of the way to dump stuff.
- These things are build to take a beating. Usually lasts a lifetime if not stored under the weather to rust away.
One of these about 1.25 m (4ft) wide costs new about 300€ (340$). I bought mine used for 100€ with the corners completely rotten but I've replace those with a thicker gauge sheet metal and it's now waiting patiently for a fresh coat of paint.
If you search "3 point tipping box", you'll see some similar stuff but not quite like mine.
Considering the prices in the US, if you can locate a good EU price, it might be worth to get it shipped to you.
I'm very surprised that these attachments are not being sold in the US yet, specially since the Chinese usually copy everything, make a cheap version and sell everywhere.
Found this in the USA, but no reviews. This is without any hydraulics. hmmm
Pat'''s Easy Mover - LivestockShed.com
In the UK these are called tipping boxes. Fleming Ag of the UK use to have a USA presence and sold a similar type, but better gauge thickness of steel.
update: Think I found the Pat product webpage to save over $100. ... Pats Easy Change 3 Point Hitch System
This can be a dirt scoop or as a carry all box. dual purpose. Then with the box off, it can be used for at least 3 other types of uses. 1 being a hay bale fork unit. It has many uses. I really like multi-use implements.
Still poking around. Folks on TBN back in 2013 were looking around too!
https://www.tractorbynet.com/forums/attachments/284808-new-3-pt-dumping-transport-2.html
Landoll Lowboy Trailer (A55315)
Landoll Lowboy...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
UNUSED FUTURE FT-CWG72-72" HYD CURVED WOOD GRABBER (A57193)
UNUSED FUTURE...
2019 Dodge Journey Crossroad SUV (A53424)
2019 Dodge Journey...
2012 Ford Escape XLT SUV (A55853)
2012 Ford Escape...
Electric Mobility Scooter (A51694)
Electric Mobility...
