Comparison KOYKER 140 LOADER for YM2610? Maybe not, what else then?
/ KOYKER 140 LOADER for YM2610? Maybe not, what else then? #21
Kinda off-topic but this seems like a good thread to post this in for someone to find in the future.
Here's the rear forks assembly I built, it's the blue part.
In this photo, I'm carrying a back blade ('Carrington Terracer') that came with the first YM186D ten years ago. I hauled the back blade up to the shop to see if I could modify it a little to use with the q-hitch. No, impossible. A second set of 3-point pins on it would have to be so high that I couldn't lift the blade off the ground. New pins much farther forward might work.
One thing I learned using the blade: Adjusting the 3-point doesn't do much to make the left or right end of the blade dig in, to crown a road. I will need to put ballast on the side that I want to dig in.
So far I've used this toy only a few minutes, over several years. Anybody need a back blade?
Another photo of the Carrington Terracer. Ain't she purty?
Ok, carry on. :)
Jansenusa DPS-800, 3pt rear bucket, 3-yr warranty.
Hydraulic Rear Shovel, Rear Loading Bucket, 3PT, Jansen DPS-8 - Jansen USA
Description
Our hydraulic three-point bucket Jansen DPS-800 incl. hydraulic hoses and connectors.
The body has a capacity of approx. 1 yard. This hydraulic rear bucket is therefore perfectly suited for loading and transporting sand, soil, gravel, wood, feed, etc.
This bucket is great for moving and clearing snow!
The hydraulic tilt mechanism requires the tractor to have a double acting controller. The bucket attaches to the three-point linkage at the back of your tractor. The flat bucket makes picking up bulk goods, e.g. gravel, sand, silage, or feed, particularly easy. When using the correct tilt the bucket can also be used to clear snow in winter!
A reinforced bottom improves wear resistance and the center pivot prevents abrupt dumping and overloading the hydraulic cylinder.
Technical specifications:
Bucket volume: approx. 1 cubic yard or 212 gal.
Body dimensions: approx. 60″x30″x27″ inches
Required hydraulic connection: 1x double acting
Load and tilt from the tractor
Mounting: Three point hitch from Cat. II
Overall dimensions: 60″x45″x34″ inches
Weight: approx. 460 lbs
Load capacity 2200 lbs
Note:The bucket is delivered well packed in a steel crate. You should allow approx. 1.5 hours for final assembly. Should you have any further questions, please do not hesitate to call us.
Important: Deliveries usually take 6-14 days, depending on your area.
Estimated delivery time dose not always reflect the actual delivery date. Lift gate requests and residential deliveries could add to the estimated delivery date.
More pixs can be found here:
Rear Bucket Jansen DPS-8 Hydraulic Rear Shovel, Dump Body | Front / Rear shovels | Agriculture & Forestry | Jansen Mailorder
/ KOYKER 140 LOADER for YM2610? Maybe not, what else then? #24
That is a category 2, a little heavy for most of the old Yanmars. 460# before you put anything in it is quite a lot.
Yep, that's why I had underlined that part. :D
What is wrong in North America not having a dirt scoop or rear 3PT bucket? I can find these all over the EU, in Asia and even in India!
This one on a M-F in action works well. Only issue is the tractor has sloppy stay bars/chains, thus the bucket keeps swinging between the rear tires.
Filling in the old pond with the massey ferguson 35 and fleming transport box - YouTube
After watching about 2-1/2 hours of these rear boxes in action or in ads, it seems the overall robust product is the Fleming unit.
fleming tipping boxes - YouTube
/ KOYKER 140 LOADER for YM2610? Maybe not, what else then? #27
Dirt scoops are present in the US. Used are available and even a few new from suppliers. If looking for used also search pond scoops.
King Kutter makes one and Northern Tool sells a few brands. There is also a style from Pat’s of Pat’s quick hitch.
/ KOYKER 140 LOADER for YM2610? Maybe not, what else then? #28
Those things are so easy to make and actually cheap but it does requires having a welder and some basic tools. No friends around to help you with tools/fabrication? :)
The first video with the MF 35 showed a bit of inexperience as well but it does the trick fine.
Nada, zip-o, no welding experience nor skills. We moved here 2 years ago, got lots of Amish, but no welders around.
Now, I did find this. A Yanmar YM1510D with a rear kippbox (rear bucket). The color match his Yanmar too! :cool2:
Note: The right lift arm is not level with the left in the vid. Needs to be adjusted.
Kippmulde 1cm an Yanmar-Kleintraktor 151D [HD] / Yanmar with tipping trough - YouTube
/ KOYKER 140 LOADER for YM2610? Maybe not, what else then? #30
That's about what I have.
First test I did when I got it, was to scrape my freshly tilled food plot. I went about 10" deep and managed to get a full box of dirt with no effort at all. That was pretty cool. Although it only that time because the lift arms aren't really made to push, they can bent or break stuff and I don't want to experience that.
/ KOYKER 140 LOADER for YM2610? Maybe not, what else then? #31
One of the reason that the pond/dirt scoop is more appealing in my opinion. Most can be pulled or pushed. In lose soil or a loose gravel/dirt pile pushing should not be a problem. If you are working hard packed material connect where you are pulling the scoop and you should spin tires before damaging any components (assuming the scoop is not rusted out). I suspect the boxes similar to those pictured above have those limits related to digging in their literature.
My issues with a pond scoop are many:
- Too narrow
- Sits further to the rear, away from the tractor, thus center of gravity is farther back and requires more front end weights (more money to by weights)
- Scoop structure gets in the way actually and the glides with release mechanism can jam as these are on the sides and not with the 3PT top link as a lever release
- Scoop structure gets in the way with the upper hoops for loading young trees to transport or even transplant
- Scoop is inside a cage, can not easily shovel out materials to fill smaller ground holes as needed.
As for the digging into the ground level, that is not my intent nor purpose with the rear bucket. Moving mulch, snow, landscaping dumped top soil, trees, and such would be the needed method.
With the box blade, I've used that as a ram, hook to pull out tree stumps, etc. Thus, the rear bucket would see much less harsh action. :p
/ KOYKER 140 LOADER for YM2610? Maybe not, what else then? #33
You've listed all the reasons you need a front loader! :) :) :)
212113d1305056771-any-ym-2000-owners-p1170597rlifttransplanttree-jpg
199681d1297306665-weight-yanmar-4ft-tiller-p1060289runloadtiller-jpg
121491d1234497227-dang-finally-broke-something-p1210480rlifttank-jpg
98140d1205688941-whats-best-way-water-plants-p1170674rwateringw25gtank-jpg
33717d1108497350-sound-file-posted-cold-start-586044-dscn5078r-jpg
Yes, but I need it in the rear. (hmm that didn't sound good.) :confused2:
At the front, a FEL isn't adaptable for my needed use and the narrow areas the tractor will need to navigate. Thus a REL (Rear End Loader) as an attachment would be ideal.
:number1:
/ KOYKER 140 LOADER for YM2610? Maybe not, what else then? #35
:number1:
You will find that a wide bucket in the rear will swing wide and cause similar issues with navigating in tight areas.
There are trade offs on every implement when you wish to use it for more things.
Many of us have found out the hard way that implements attached to 3 pt hitches swing wide and unless careful hit and sometimes damage things. The longer and wider off the back the worse this is. Just because it is fixed in the rear does not mean it does not cause issues. While I will give you that the frame work especially for reversible dirt scoops, I believe you are wrong on many other points related to the dirt scoop, its center of gravity is more forward than what you claim to want. That is why the dirt scoop is narrow! A good portion of the dirt scoop fits between the lower lift arms. That is just not possible with a wider bucket on the 3 pt hitch. Your described bucket will require more front weights than a dirt scoop will. As for shoveling out small amounts of dirts, put the opening to the rear and the biggest limiting factor is the amount of dirt you can carry. Yes you have a narrow area to target, but plenty wide for even a scoop shovel I have used in grain trucks.
And at $300+/- used dirt scoop is a long ways from $4600 FEL. And half of Pat’s easy mover bucket. It leaves lots of money to buy/build a carry all that would be more open. Some times you do indeed more than 1 implement for a all jobs.
I'm not looking for anything huge. I have a compact tractor. A rear bucket the size and space of my rear box blade is my intent. This way, I can manage navigating any bucket loads with ease.
Additionally, I have the better stay chains on the tractor arms from Hoye. I've even added a few extra items to ensure the durability with them. In my implement listing, the rear disc-harrow and the brush mower are huge vs. the box blade or a hopefully the rear bucket. :cool: Thus, if I had any swing action, I would have noticed it by now.
Another option I did was to replace the pivot bolts where the lower arms attache to the tractor. With the better bolts, huge nyloks, thick and large fender washers, the sway is greatly eliminated to zero. It took some engineering to figure out how to stabilize the lower arms as my old JD-261 finish mower was awful with sway on them.
/ KOYKER 140 LOADER for YM2610? Maybe not, what else then? #37
In my opinion if your “bucket” is no larger than a box blade, it is less useful than a dirt scoop. In my opinion you have convinced yourself of an untruth. Unfortunately, you will only learn by doing (the hard knocks school). But that is ok, you are the one that told me my tractor has glow plugs, I proved you wrong on that from the picture you used to justify your error!
Good luck to you on spending unwisely!!!!
I now unsubscribe to this conversation!!!
Here's a quick pix of the lower arm with the washers and nylok in place. This has helped a good deal to prevent swaying outwards towards the rear wheels.
635840d1578366346-koyker-140-loader-ym2610-maybe-dscf6445md-jpg
This next image is with the added Hoye stabilizer chains with added hardware
635841d1578366490-koyker-140-loader-ym2610-maybe-dscf7063md-jpg
635842d1578366521-koyker-140-loader-ym2610-maybe-dscf7065md-jpg
It seems I've fully narrowed down the rear bucket. Winston thanks for the tip.
The bucket is only 44-inches (3.5-FT). Just a little less wide than my box blade. Perfect size really. There are many lawn tractors and SCUT's that use this too.
44" Universal Dump Bucket 15714 - FREE SHIPPING
https://www.homedepot.com/p/Swisher-Dump-Bucket-15714/202984964
Every time I find a image search for a tractor with this bucket, it's on that pintrest site. So, linking or posting here wouldn't work. I'll keep looking. The setup and attaching is rather simple. Just need the CAT-I pins mounted in the flanges.
Ah-ha, found an excellent link. This SCUT is using the Swisher dump bucket with the adapter kit for a Cat-0.
Fabricated Dump Bucket
2022 Ford F-450 Liftmoore 5000W 2.5 Ton Crane Service Truck (A59230)
2022 Ford F-450...
2007 Ingersoll Rand G240 240kVA 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
BRINLY 41" AERATOR (A60430)
BRINLY 41" AERATOR...
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A59231)
2009 Mariah SC23...
2016 FORD TRANSIT 350 CARGO VAN (A59905)
2016 FORD TRANSIT...
