buckeyefarmer
Epic Contributor
This day in 1997 I was three years short of retirement.
Cool. I hope to be about 3 yrs away or less right now.
Question, When tyvek goes to the top of the outside wall, do you tape it to the wood all along the top to keep air from getting in behind it? Same at the bottom? Not sure I致e ever seen it done.
I don't use house wrap anymore, I like Zip System a lot better.
When I did house wrap, I installed it before the rafters or trusses went on. It's 9 feet tall, so I start at the bottom and then get it over the top plates and attach it to them. Then when the roof is built, it's on top of the house wrap that's on top of the top plates of the walls. If it's a taller wall, or a gable end, I do the same thing by starting at the bottom and then overlapping it on the higher portion so there is a foot of overlap, but I'm sure 6 inches is plenty. That seam gets taped. I never had much faith in that tape since the few times I've taken down walls that where taped, the tape had dried out and wasn't doing anything, anymore. I don't know what brand of tape it was, or if newer versions are better. Zip Tape is the best tape that I've ever come across, so that's part of why I like Zip System so much. Then I do the same with the higher up roll of house wrap and get it over the top plates.
Lost track of how many times I said "should have got a pocture of that"......
