Texasmark
Elite Member
- Joined
- Apr 24, 2012
- Messages
- 3,715
- Location
- N. Texas
- Tractor
- Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
To counter the don't worries, my 2007 65 hp says the same TDH fluid, but 24 hp 2016, both Bransons, says 90w gear oil and it's even molded into the fill port plug/dip stick so you won't forget what's required. Read between the lines. On front axle having an easy life, quite the contrary! Story after story of broken axles on here and other places, pictures you wouldn't believe if you didn't see them, a "supplemental drive system" used for the main traction element over and over again.
last time I changed the front end oil in my 6530, 85w-140 went in and haven't worried about it since. Had I lived up North it would have been 90w due to the colder ambient temps.
