ericm979
Super Member
- Joined
- Nov 25, 2016
- Messages
- 5,818
- Location
- Santa Cruz Mountains CA, Southern OR
- Tractor
- Branson 3725H Deere 5105
I'd use the same hose size as the existing loader hoses. It's probably 3/8 or maybe 5/16 like mine. You don't need 1/2 all the way, it doesn't flow that much. The smaller hoses will be easier to route and cost less too. You will need 3/8 quick connects to plug into the loader quick connects.
If you're clever and the stock stuff is routed right, you can use the existing hard lines with your diverter. You'll need short hoses from the diverter to the tees to the cylinders.
Rather than guessing on hose lengths, use a piece of old garden hose to mock up the routing and measure that. Surpluscenter sells hoses in 6" and 1' increments. That's the least expensive option. DiscountHydraulicHose is a better deal for custom lengths. I dislike NPT for hydraulics- you have to tighten the heck out of them and use a sealant to get them to seal. I use adaptors for NPT fitting like quick connects and then use JIC for everything else. Hoses with female JIC swivel ends are super common and almost as cheap and ones with plain NPT.
