GC1725MB backhoe hydraulic lines
/ GC1725MB backhoe hydraulic lines #1
Flatrockcorner
Massey Ferguson GC1725M
Just curious how you guys tied up or stowaway the hydraulic lines when you don't have the backhoe on the tractor?
/ GC1725MB backhoe hydraulic lines #2
If you're talking about the long looped line and the tank line on the tractor side after removing the backhoe, then grab a couple bungee cords. If there is no implement on the 3PH, then I just use a bungee to the backhoe mount pin location. You can also use a bungee and secure it to the seat belt anchors, seat frame, ROPS base (under the plastic)...you get the idea. There is not a decent manufacturer allowance for securing the lines. If you have a 3PH implement, beware of the swing path and if you have a driveline in use, be very cautious of that also.
/ GC1725MB backhoe hydraulic lines #3
Like this:
/ GC1725MB backhoe hydraulic lines #4
Speaking of backhoe lines anybody have any good information on how they connect to FEL "BP" port and "P" port of 3PH control... Think I am getting handle on how to do power beyond with same lines as BH but have a idea that the diagram in shop manual has some errors...
Dale
/ GC1725MB backhoe hydraulic lines #5
For me it takes trial and error as I have multiple configurations-BH, Snowblower, box blade and Post digger. I have gone through at least one hose to get it right.
/ GC1725MB backhoe hydraulic lines #6
Dale
Here is the information I think you are looking for in the thread of the link listed below, Post #9, #12, & #14 especially.
https://www.tractorbynet.com/forums...89305-can-hydraulics-backhoe-used-adding.html
This is the way I understand the flow of hydraulics from the FEL to the BH to the 3 point hitch:
The hydraulic supply line from the FEL Power Beyond (PB) port has a male coupler end located at the rear of the tractor, and is called "the Pressure Hose (1)" in the MF Backhoe Manual, which connects to the female coupler end coming from the backhoe's Pressure Port (P) valve assembly.
The male coupler end of the hose coming from the backhoe's Power Beyond (PB) port valve assembly connects to the female coupler end of the hose called "the Return Line (2)" in the MF Backhoe Manual, and is located at the back of the tractor and then goes to the Pressure Port (P) of the tractor's "3 point hitch" valve assembly.
The couplers in red above connect together when the Backhoe is removed.
The male coupler end of the hose coming from the backhoe's Return (T) Port valve assembly connects to the female coupler end (this hose coupler end remains loose when the backhoe is removed) of the hose called "direct return to the transmission sump (3)" in the MF Backhoe Manual, and goes to the "transmission sump tank".
I have been thinking about these hydraulic flows/connections for about 11 years now and I still do not have a real good grasp of it.
I hope this helps you with our tractors hydraulics flow...
KC
/ GC1725MB backhoe hydraulic lines #7
KC
I am pretty much in agreement with your description, but the two things the elude me is what connection is used on control valve body of 3PH as the "P" (from BP of BH) port for 3PH..
Graphic provided is what I believe to be a "correct" copy of partial hydraulic system as I believe the one in shop manual has at least 3 errors in way its drawn...
Dale
/ GC1725MB backhoe hydraulic lines #8
Dale
All I know is what I have learned over the years and am still learning about tractor hydraulics.
The main flow of these valve assemblies is:
Hydraulic flow into the valve connects to the "P" port,
and hydraulic flow out of the valve connects to the "PB" port,
and the hydraulic so called over pressure flow back to the tank from the "T" port of the valve.
Our tractor valves appear to be an "Open Center" valve and each valve has a power beyond port to flow to the next valve.
This is why it's a must to connect the 2 hoses from the backhoe when it's removed, to complete the flow of hydraulic fluid to the 3 point hitch.
I'm not sure if I answered your post above, but I'm sure if I was to read my post above 10 years ago it would of been way over my knowledge back then about hydraulics.
Back then it was more important and hard enough to figure out all of the tractor levers.
KC
View attachment Prince Valve with 2 remotes.pdf
/ GC1725MB backhoe hydraulic lines #9
KC
You are right on 100 %.... I have come to same conclusion, I am just trying to get real good handle on where the plumbing actually connect on physical equipment, and it occured to me that if I tear into tractor and remove hose from "BP" of FEL to "P" of control valve for 3PH, I have exact location for where beyond power hoses connect (aka BH hoses) ... Only thing is I still can not seem where "T" hose for BH connect, but I may not need that if using simple valve assembly for something like log splitter. (with open spool) ..
Dale
/ GC1725MB backhoe hydraulic lines #10
This is LD1's post (#9) from my link, of my post #6 above:
12-22-2017, 04:46 AM #9
LD1
LD1 is offline Super Star Member LD1's Avatar
Join Date:Apr 2008Posts:19,067Location:Central OhioTractor:Kubota MX5100
Default Re: Can hydraulics for backhoe be used for adding rear controls for hydraulic attachm
"You need a valve for your remotes.
So you need to decide on 2 remotes, 3, etc.
Valve needs to be open center, AND have an optional power beyond plug.
The line currently running to SUPPLY the backhoe needs to be re-routed and NOW supply the new remote valves.
The Power beyond out of the new valve needs a hose added to get back to where your backhoe hookup was. This is the new supply for the backhoe.
You need to ADD a return to tank somewhere from the new valve. This can be Tee'd in anywhere with an existing return line. (the backhoe return is NOT an actual return line, rather that is the feed for the 3PH).
Then you need to add your rear couplers.....mounted however you wish.
You still need to couple the backhoe lines together when backhoe is detached."
I believe LD1 has explaned it so I can even understand it...
KC
B.T.W. do you plan on mounting your valve upfront near the joy stick or in the back near the ROPS?
To me, it would be a easier plumbing job in the back...
/ GC1725MB backhoe hydraulic lines #11
I was thinking in back to possibly power a log splitter mounted on 3PH.... I know it will be slow, but so am I (because I'm old) and I don't do that much splitting....
Dale
/ GC1725MB backhoe hydraulic lines #12
Dale
A while ago I was thinking like you are about a 3 point mounted log splitter, PTO and hydraulic.
Heck I even thought of a standard gas power log splitter towed behind the tractor or mounted to a modified "3 point carry-all" (wood platform with log splitter strapped down to it).
But in reality, I only have 3 acres of wooded land, and now I usually:
1). skid the trees (cut to about 16') to the outside area of my woodshed for processing.
2). cut the logs to 9' and either skid the logs or use my bucket mounted brush forks to transport the logs to the outside of the woodshed.
3). and after 11 years we only had 1 nasty winter that toppled over 50 trees.
I have learned to hate handling wood over and over especially after our 1 nasty winter and splitting all of that wood in about 6 locations (my neighbor towed his gas powered log splitter with his UTV to these 6 locations) throughout the property.
My current system is to cut the logs (outside of the woodshed) into 18" rounds, load them on the wooden platform on top of the bucket mounted brush forks, drive into the woodshed and dump the load.
We will stack the rounds inside the woodshed and work our way out, and the woodshed can hold about 20 cords.
In the summer we get all of the last winter downfall trees cut into 18" rounds and into the woodshed and during the winter I'll use the 7 ton electric wood splitter as needed to split wood and kindling for 2 garden wagons (this process is done in the woodshed and the loaded wagons are pulled into the house and staged next to the wood burning stove).
Oh I forgot to mention the best part of this "on demand splitting", I am sitting down on a 3 gallon bucket with a cushioned bucket lid doing the wood splitting...
This splitting on demand has worked well for me because for the past 4 years, and being old, it extends the manual work required out to many more days; of about 10 minutes + - to fill 2 wagon loads of wood when required (usually just 1 wagon load a day after late Dec. and Jan.).
Everyone has to find out what works for them, and for me I seem to always make little adjustments when I find an easier and more efficient way.
KC
Sorry to be off topic...
/ GC1725MB backhoe hydraulic lines #13
KC
BUT you are splitting about 10 to 15 time more than me.... I have maybe 15 round sitting and maybe 15 more to be created this season...... Last year neighbor came over brought his splitter we split for about 3 hours for 2 days ... He got half the wood for splitter "rent"....Still have some of the wood ... Don't even know why I am thinking splitter, but the challenge came to create "power beyond" because sales brochure said it was available... But according to AGCO, its not, PB is only used on backhoe models... And most shop manual data is non existent for tractor side of backhoe equipped units...
Oh well nuf said....
Dale
/ GC1725MB backhoe hydraulic lines #14
And I di figure out MF/AGCO has a few errors in it shop manual for hydraulic diagram for BH plumbing on the 1705-1720......
Error...
Correction...
Dale
2017 Ford F-550 Mason Dump Truck w/ Liftgate (A59230)
2017 Ford F-550...
2015 Ford F-350 Versalift Bucket Truck (A59230)
2015 Ford F-350...
KUBOTA ZG23F ZERO TURN LAWN MOWER (A60430)
KUBOTA ZG23F ZERO...
UNUSED KJ K2010 HEAVY DUTY CHICKEN COOP (A60432)
UNUSED KJ K2010...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
UNUSED FUTURE MINI EXCAVATOR GRAPPLE (A60432)
UNUSED FUTURE MINI...
