Mobile Fueling Station.
   / Mobile Fueling Station. #1
bindian
Super Member
Willis, Texas
Mahindra 6520 4WD
I have have been wanting to make more diesel storage and an easier way than lifting 5 gallon jugs of fuel. I picked this aluminum L tank last spring at a RB Auction. 4-3-20 Transfer Tank Back.jpg4-3-20 Transfer Tank Corner.jpg4-3-20 Transfer Tank End.jpg
I used home cut 2x4s and 2x6s over 4 inch (actually 4.5 inch) square skids. I brushed on 3 coats of Copper Naphthenate 8% (68% by Volume) Concentrate. It is diluted one gallon of concentrate to 3 gallons of diesel.
http://poles.com/epages/08fd78c5-ab...5-abfa-4217-9263-68fec9605ccc/Products/WP4014
It truly stinks as the smell came through 2 pairs of rubber gloves and made me very happy, even while wearing a half face respitator. I can't imagine any bugs or even critters trying to get under this stinker.
I will be installing this 15 gpm pump this, rainy, weekend.4-3-20 Transfer Pump In A Box.jpg
So I will be able to put the forks on the Mahindra and load or unload it, or fuel my toys, eh....machines.
hugs, Brandi
   / Mobile Fueling Station. #3
I put plywood sides on mine to help protect against denting should I screw up and bump into it with my pallet forks or anything else. I also made a steel wheeled dolly to set it on so I can wheel it around the shop. It's very handy and sure beats lifting heavy 5 gallon fuel containers. You are gonna like it.
Skipper B,
Plywood sides is a good idea. Mine is gonna be stored outside and I will put a tin roof on it.
hugs, Brandi
   / Mobile Fueling Station. #5
I made mine with a 50 gal. Reefer tank in a wooden frame. I put it on two HF dollies in the shop so easy to move wherever needed.
Once, I bid on a pair of 50 gallon aluminum saddle tanks. I was outbid.
How about posting photos of your reefer tank?
hugs, Brandi
   / Mobile Fueling Station. #8
I have have been wanting to make more diesel storage and an easier way than lifting 5 gallon jugs of fuel. I picked this aluminum L tank last spring at a RB Auction.View attachment 648925View attachment 648926View attachment 648927
I will be installing this 15 gpm pump this, rainy, weekend.View attachment 648928
hugs, Brandi
Nice job! Thanks for posting. I’m always looking for ideas for a fuel station.
No problem. Glad I could help your idea pool.
hugs, Brandi
   / Mobile Fueling Station. #10
hugs, Brandi
I put mine on a used second hand Harbor Freight trailer frame - so I can tow it around as needed, move it around in the garage etc. Split setup, 75 gal diesel, 75 gal unleaded.fuel trailer (1).jpgfuel trailer (2).jpg
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
2011 Jacobsen T-700 Reel Mower (A56857)
2011 Jacobsen...
Kawasaki Mule 2510 4X4 Utility Vehicle (A55853)
Kawasaki Mule 2510...
BAUER ATD-750 VERTICAL HYDRAULIC PIPE HANDLER (A58216)
BAUER ATD-750...
Kubota RTV Bed (A57149)
Kubota RTV Bed...
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
