How may tubes of grease do you go through greasing at 50h intervals?
/ How may tubes of grease do you go through greasing at 50h intervals? #41
Now if anyone knows where I can get a 35lbs pail of Amsoil Synthetic Multi-Purpose grease shipped in Ontario, Canada at a decent price
Order it direct from AMSOIL and get 25% off and free shipping ►Save up to 25 percent on AMSOIL products
They have distribution center in Toronto.
Once grease is open it should not sit around. I have seen people with grease guns hanging in cold barns for months if not years on end, bad practice (separation and contamination). ONLY buy enough to last 6 months and store in controlled climate, see chart.
source: 10 Ways to Improve Lubricant Storage and Handling
Synthetic Polymeric Off-Road Grease, NLGI #2
I guess I am about to find out how bad grease is after 5 years... I wonder if this chart is conservative. Has anyone done a study on this? Does it matter if you keep the grease sealed, or even under vacuum?
/ How may tubes of grease do you go through greasing at 50h intervals? #43
How many tractor are you greasing ?
Still just one tractor, and one garden tractor/mower.
/ How may tubes of grease do you go through greasing at 50h intervals? #45
Would just 1 case of grease and a hand grease gun work .... seems like a lot for just two tractors not to be a a**hole but......
I know it's way overkill. I do that a lot ☺
One thing is for sure, I'm not throwing out a pail of grease after 6 months, just because. Shelf life is 3 to 5 years, unopened. I really don't see how open containers go down to 6 months, unless you are scooping out the grease with a sandy wet shovel and you store the pail near a steam boiler.
Good info on lithium vs calcium carbonate grease though. Lithium seems to have twice the shelf life, no matter where you start. Another advantage, besides pumpability.
/ How may tubes of grease do you go through greasing at 50h intervals? #47
If you lived closes you could use this I have not used it in twenty years...........air grease gun.jpg
/ How may tubes of grease do you go through greasing at 50h intervals? #49
I use my loader primarily for snow removal and grease EVERY time I use it. So I grease the loader about every 3+/- hours. Sure my loader arms are slobbering grease and I may be wasting it, but grease is way cheaper than loader pins and bushings and not as hard to remove.
I've got a battery operated cartridge gun. I get the grease a case of 10 tubes at a time.
/ How may tubes of grease do you go through greasing at 50h intervals? #50
No I just don't use it I have a little cart with a gear oil pump also....And a 25 foot auto reel grease hose..grease cart.jpg
Thanks Z71, so far the Amsoil is my best option. Not cheap, but specs are very good on their synthetic multi-purpose. Also nice to only have one grease around, it will do bearings and all.
/ How may tubes of grease do you go through greasing at 50h intervals? #52
You should grease tractor parts such as the backhoe or the loader arms each time you use it in dirt the pins get dirt in them and the grease will push it out.
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
Toro Sand Pro (A56859)
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
(4) UNUSED FORERUNNER 12-16.5 SKID STEER TIRES (A60430)
(4) UNUSED...
2018 F550 Bucket Truck (A61306)
2018 F550 Bucket...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
