How to make water bars in a driveway?
   / How to make water bars in a driveway? #1
Garrett2006
Massey Ferguson 2706e
Looking for some good info or video on how to make water bars in a gravel road the proper way. I have a driveway repair job coming up and e customer wants them added in the driveway. I知 sure several on here have some good advice on making them. I値l be using the box blade and land plane to redo his driveway, but have a skid steer if that痴 need to construct the water bars. Thanks
   / How to make water bars in a driveway? #2
We made these from pressure treated 2x4’s and a 2x6 and 2” pipe nipples. Sunk 3 of them into my sister-in-law’s gravel driveway. They have controlled erosion really well. They can be kept clean of leaves and debris with a leaf blower. IMG_0119.jpg
   / How to make water bars in a driveway? #3
   / How to make water bars in a driveway? #4
The first rule of designing any type of storm water runoff system in simple terms is "the year storm size"...
...A swale designed for a 25 year storm can be much less severe than one designed for say a 100 year storm...
Assuming there is no crown (defeats the purpose of a bar or swale etc.) the lane should be pitched enough to the low side so only minor accumulations reach a swale...the runoff should run across the lane not down it...the latter will always cause wash ruts...
Effective swales can be quite mellow and not seem like speed bumps etc...
   / How to make water bars in a driveway? #5
We made these from pressure treated 2x4’s and a 2x6 and 2” pipe nipples. Sunk 3 of them into my sister-in-law’s gravel driveway. They have controlled erosion really well. They can be kept clean of leaves and debris with a leaf blower. View attachment 650289
Be certain to use ground contact PT.
The standard PT from the big box stores is usually junk.
You need .60 CCA treatment
   / How to make water bars in a driveway? #6
I built one with a 2x10 and a 4x4 on either side allowing a 2" trough. Pricey but very strong.
   / How to make water bars in a driveway? #7
What I do is put a small furrow in mine at a steep angle.
   / How to make water bars in a driveway? #9
The rubber belting is how New Hampshire does it on the atv trails in the state forest......
   / How to make water bars in a driveway? #10
I like the wooden ones and the wood and belting ones but I would wonder about snow plows in the winter,
and it would be quite a bit of labor to install and remove every year.
Jumper Cables (A53316)
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A55851)
2024 Wanco...
2017 KOMATSU PC290LC-11 EXCAVATOR (A52706)
2017 KOMATSU...
Bobcat 873 (A47477)
Bobcat 873 (A47477)
2001 Dodge Durango SLT (A53314)
2001 Dodge Durango...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
