How to make water bars in a driveway?
   / How to make water bars in a driveway? #11
I've also seen them made with old fire hose.
   / How to make water bars in a driveway? #12
I just use earthen humps on an angle, terminating the downhill ends with rip-rap to keep erosion at bay as it diverts road surface water into the ditch. I then put an rock check dam in the ditch, across the ditch, to prevent ditch erosion. (These can be seen in the photo)
I do that just because I plow my Heavy Haul Roads all winter, and figure if I plow them out, I can put the angled swales back for free, instead of having a rubber razor or box culvert to replace at a cost.
I think it looks professional, and is functional, but what "looks good" is subjective.
For what it is worth, this road, on a 9% grade, in soil characterized as Highly Erodible Soil, was approved by the US Dept of Agriculture, and met the Federal Soil Engineer's specifications for this road. The right side rock check dams have nothing to do with the swales; they are just for ditch erosion control, but the left side is just for erosion control of the water being diverted to the ditch by the swales. Just as a note, this road looks flat, but truly is a 9% grade, which is about the maximum a truck should be climbing/descending. The photo is an optical illusion.
   / How to make water bars in a driveway? #13
If you can find used guardrail, it makes excellent waterbars. I got lucky and found some at a scrap yard, but there are businesses that exist specifically to resell used guardrail. It's used for cattle fences and all sorts of other projects. The US Forest Service recommends it for waterbars and other types of drainage control. There are a few videos on youtube about this.
More info and some videos here: https://www.tractorbynet.com/forums/rural-living/421209-trench-channel-drain-gravel-driveway.html
So you just pile up the material at an angle across the road and pack it in? I like what you have and it’s what I looking to do with rock and crush and run material. I’m interested in exactly the process of making the swales in the road to stay and not wash over time like you have. Thanks
   / How to make water bars in a driveway? #15
Exactly! Guardrail will last a LONG LONG time and works great.
   / How to make water bars in a driveway? #16
Just a question, would the highway department have used guard rail?
   / How to make water bars in a driveway? #17
Also check recycling plants and Craigslist.
   / How to make water bars in a driveway? #19
So you just pile up the material at an angle across the road and pack it in? I like what you have and it痴 what I looking to do with rock and crush and run material. I知 interested in exactly the process of making the swales in the road to stay and not wash over time like you have. Thanks
You can make it two different ways, depending of course on what you have for equipment.
1. The first way is to take a backhoe or the bucket of your loader (it does not have to be a big backhoe) and scrape the road down from the uphill side, to the bottom. This creates a berm. That berm should be about 30 degrees of an angle across the road. Then just take a garden rake and rake out the berm so that it is a smooth transition. It does not have to be a long, deep berm...water will take the path of least resistance, and obviously drain downhill.
2. If you do not want to scrape down into the road, then you can always just form a berm at the 30 degree angle, by hauling in gravel and placing it across the road. Then raking it out so that it is a smooth transition.
I think mine are something like 6 inches deep...maybe 8 inches at most, with the berm tapered back by four feet on the downhill side of the road. Just be sure to rip-rap where the waterbar terminates in the ditch because it channels an amazing amount of water in that one spot.
I thought my truckdrivers would complain as they rode over the (4) waterbars that I put in, but when they never complained (and truck drivers ALWAYS complain), so I mentioned it, and they said they never even gave it a second thought. And they were rolling over them with 100,000 logging trucks.
   / How to make water bars in a driveway? #20
If your grade is shallow enough, I prefer broad-based dips to waterbars. Broad-based dips hold up well and are easy to drive through, a true waterbar in the forestry sense is a bit of a pain to drive through (let alone plow, if you are in snow country). Unfortunately, broad based dips don't really work on grades steeper than about 7%. Since you mentioned a 9% grade, that option may be out.
I've seen rubber belting with one edge sandwiched between two PT 2x6's. I've heard it worked well at redirecting water. I'm not sure how it stood up to occasional snow plowing (it was more of a "back 40" access road, than a daily use driveway). They tipped the rubber over to lean fairly heavily to the uphill side, and angled it across the road to direct the water off. During heavy rains the rubber might stand up a bit, but it would not flop all the way over to the downhill side. The idea of tipping it uphill was that it would both hold water running down hill, and stand up well to plowing if you only plowed when going up hill (you would just lay the rubber down, rather than catching it when plowing.) I never did stop by after that first winter to see how it worked when plowing.
I've been temped to try the box culvert or guard rail on my own driveway, but figure I'd constantly be catching it with the snow plow.
2015 EAST MANUFACTURING ALUMINUM SPEAD AXLE STEPDECK TRAILER (A58214)
2015 EAST...
2024 Timpte 40ft Hopper (A56438)
2024 Timpte 40ft...
24017 (A56859)
24017 (A56859)
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
CATERPILLAR 259D SKID STEER (A60429)
CATERPILLAR 259D...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
