the best carb cleaner
   / the best carb cleaner #1
weeder
Tuscola Illinois
John Deere 425 lawn tractor
My engine is hard to start and runs a little rough, was wondering what might be a good additive to add to the gas to help clean out the carb? This is on a John Deere 425 with a Kawasaki engine.
Thks Weeder
   / the best carb cleaner #2
I use Sea Foam in a gallon jug. I add an ounce to every 5 gallon gas can of fuel for the mowers.
   / the best carb cleaner #3
Seafoam is of limited benefit for 4 stroke engines. It was originally developed for 2 stroke outboard motors.
Use a fuel system cleaner that contains PEA. I prefer Gumout or Techron. Both work well, are available at Walmart. Pick the cheapest. Either will remove fuel system varnish and deposits as well as clean up the valve stems and combustion chambers of carbon. Don't overdose. Follow the directions and be prepared to change engine oil after 10-20 hours of operation due to carbon soot in the oil. Thereafter, quality engine oil should be used to help keep the engine clean. Your fuel filter may need a change after treatment. While your engine is water cooled (I believe), I run Mobil1 5w-30 in my B&S Vtek twin. Synthetic engine oil in these smaller engines provides measurable benefits. Don't overlook valve lash adjustments...keeping the lash in spec can improve cold starts, improve engine power and help the engine run cooler. Also, clean and gap the sparkplugs. I always run plug gaps a little tight (0.003"-0.005" under spec)...helps cold starts.
   / the best carb cleaner #4
I love seafoam and use it to stabilize all my occasional use engine fuels but I don't use it as a carb cleaner. I was trained as a marine mechanic and leaned about it X years ago and still use it today.
   / the best carb cleaner #5
Thks Weeder
Take the carb off, order a kit and clean/rebuild it.
   / the best carb cleaner #6
Seafoam. Just throw a dollup into the tank.
It has worked so many times to fix a carb problem on 4 CYCLE ENGINIES.
Ralph
   / the best carb cleaner #7
Ralph
You get a million opinions on a site like this but I have to say I've had excellent results with seafoam so I keep on using it. I use their carb cleaner with the straw applicator on my GDI Ford engine every oil change.
   / the best carb cleaner #8
IMO the best carb cleaner is a clean air and fuel filter...!!
   / the best carb cleaner #10
Ralph
Check the MSDS for Seafoam;
1- Oil
2- Naphtha
3- IPA
Not much happening with Seafoam. Makes a good hand sanitizer.
2010 Deere 318D (A60462)
2010 Deere 318D...
2017 Ford F-550 4x4 Ext. Cab Mason Dump Truck (A59230)
2017 Ford F-550...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
2010 John Deere 8320R Tractor (A59814)
2010 John Deere...
17101 (A55851)
17101 (A55851)
