Compare to John Deere 5065E
/ Compare to John Deere 5065E #1
Jlblake
Marquez, Texas
John Deere 2030 Diesel
I'm about to buy a new tractor. I have a good rapport going with the John Deere dealer and have numbers to work with. I have not had much communication or response from the Kubota dealer. I've heard JD is more expensive but holds the value better. My quick conversation with the Kubota dealer indicated that Kubota is actually more expensive. I'm sure the tractors are not really comparable...but I could be wrong. I'm looking at a John Deere 5065E with FEL, pallet forks and 6' cutter. It is 4WD. Here is my question:
What is the most comparable Kubota?
Thanks!
/ Compare to John Deere 5065E #2
Get the JD 12/12 reverser transmission. Kubota is a solid tractor too. It was my experience too, the orange tractor cost's more. But I also have a JD dealer 4 miles from my house too, JD was clearly the best option for me.
/ Compare to John Deere 5065E #3
You hope you don't need the dealer. JD "might" have a better resale value, but not if you are unlucky enough to buy a poorly engineered model or version. There were 5000 series that were not very good.
In my opinion, getting a 'bad" one is less likely with Kubota. Not so over-engineered.
For what it's worth, I would try and buy a Kubota AG tractor, over JD if I had to buy one tomorrow.
/ Compare to John Deere 5065E #4
Kubota M6060 will be closest in power, hydraulics, and physical dimensions other than weight. The JD is a little heavier.
/ Compare to John Deere 5065E #6
I have seen Kubota Ag tractors come into friends shops, and I just looked at them and thought, I wish my JD 6200 Idled that smoothly! I need to up the idle speed a bit to get things to stop shaking. But then it's really not idling anymore.
/ Compare to John Deere 5065E #7
I can not make a direct comparison for you but I have a M6800 Kubota and a 5525 JD. The Kubota has its strengths but the JD does also. My M Kubota has quiter engine and runs very smooth and the JD is little louder but is also 20 hp larger. What I would look at is the transmission for synchronized gears and range shifters. How the draft control works. On mine big difference. How the hyd levers operate. Can you feather hyds, if you are getting a fel does one operate the curl and lift at same time and the other not. Is the clutch a wet or dry clutch. Same on the brakes.
JD 5000e is not the only 5000 model JD. Per JD web site not made in same country and some features are different. JD 5000e is not the only 5000 model JD. Per JD web site not made in same country and some features are different. Don't assume the different 5000 JD models are the same.
Would you guys pay $1,621 for a 5 year bumper to bumper warranty?
/ Compare to John Deere 5065E #9
No. Chances of needing it due to a defect is pretty low. They aren’t going to cover operator negligence that causes the vast majority of problems.
Thanks. That's what I was thinking. I just want a simple transaction with no hidden costs...seems like that's too much to ask. Just got the final approval and it's $1,460 more than we discussed...this is like buying a car almost.
Getting my first tractor:
5065E Power Reverser Transmission, with MFWD
520M loader
MX6 rotary cutter
Frontier AP12G pallet forks
Getting 2 chains, 2 binders and 2 ratchets thrown in (United Ag & Turf deal)
Getting $250 off a $399 chainsaw
Includes the standard insurance but no extended warranty
$42, 295
Does this sound like a reasonable deal? I'm sure it's not the best but is it pretty good? Is there anything else I should ask for or expect?
/ Compare to John Deere 5065E #12
520M loader
MX6 rotary cutter
$42, 295
Read up on the MX-6 mower. I forget which gear box is a problem with breaking shafts. One gear box is from Spain, the other from China.
Does the 520M loader fit on the 5065E? Their website only lists: 5220, 5320, 5420, 5520
It's been many years since I bought a tractor and I couldn't get Deere to negotiate a price, so compared to what I paid, it seems to be a decent price.
8' 3PT BOOM POLE (A60430)
8' 3PT BOOM POLE...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
ExMark Vantage 48in Stand-On Commercial Zero Turn Mower (A59228)
ExMark Vantage...
DEUTZ MARATHON...
2023 MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
2023 MORBARK WOOD...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
