/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #361
No. A half an hr job as I followers the manuals recommended service. 50 hrs is an oil change, check bolts, check fan belt tension and grease everything. It says to do hydro at 250 hrs. I checked the hydro fluid and it was clean and didn’t smell burnt.
They don't have you do the hydro and front axle at 50 hrs anymore? Hmm.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #362
That jb weld repair work out?
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #363
It sure did for me, i just wanted to add surface for the RTV gasket. Wasnt needed for structural support, the metal was aluminum. I also used JB Weld brand RTV (silicon gasket).
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #364
Lots of praise to you, that's quite a project.
And does this mean now you have many grease smudges on your computer's keyboard, ha
KC
It worked well so far-everything is back together and no leaks, I am doing the rest of the 250 hour service shortly. I used a printout of what I got on tractorbynet so the grease and oil smudges are on the paper and shop manual only :)
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #365
Great that this all worked out well
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #367
Little bit of slope mitigation. 8yds of material.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #369
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #370
Well, that looks great. very clean lines
Thanks, all FEL work due to room constraints.
The customer didn’t want to go past the trees, I would have doubled the material and set it out further, lessening the slope even more, but it came out pretty well.
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A56436)
2023 Kubota U48-5...
2016 Hino 195h Truck, VIN # JHHSPM2H5GK001607 (A57453)
2016 Hino 195h...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2023 Chevrolet Tahoe SUV (A56859)
2023 Chevrolet...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
