/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #361
No. A half an hr job as I followers the manuals recommended service. 50 hrs is an oil change, check bolts, check fan belt tension and grease everything. It says to do hydro at 250 hrs. I checked the hydro fluid and it was clean and didn’t smell burnt.
They don't have you do the hydro and front axle at 50 hrs anymore? Hmm.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #362
That jb weld repair work out?
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #363
It sure did for me, i just wanted to add surface for the RTV gasket. Wasnt needed for structural support, the metal was aluminum. I also used JB Weld brand RTV (silicon gasket).
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #364
Lots of praise to you, that's quite a project.
And does this mean now you have many grease smudges on your computer's keyboard, ha
KC
It worked well so far-everything is back together and no leaks, I am doing the rest of the 250 hour service shortly. I used a printout of what I got on tractorbynet so the grease and oil smudges are on the paper and shop manual only :)
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #365
Great that this all worked out well
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #367
Little bit of slope mitigation. 8yds of material.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #369
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #370
Well, that looks great. very clean lines
Thanks, all FEL work due to room constraints.
The customer didn’t want to go past the trees, I would have doubled the material and set it out further, lessening the slope even more, but it came out pretty well.
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
1762 (A58375)
1762 (A58375)
2006 IC Corporation PB305 Bus (A56858)
2006 IC...
1992 Ford L9000 Cab Chassis with Low Mileage Cummins (A56436)
1992 Ford L9000...
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
