/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #361
No. A half an hr job as I followers the manuals recommended service. 50 hrs is an oil change, check bolts, check fan belt tension and grease everything. It says to do hydro at 250 hrs. I checked the hydro fluid and it was clean and didn’t smell burnt.
They don't have you do the hydro and front axle at 50 hrs anymore? Hmm.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #362
That jb weld repair work out?
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #363
It sure did for me, i just wanted to add surface for the RTV gasket. Wasnt needed for structural support, the metal was aluminum. I also used JB Weld brand RTV (silicon gasket).
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #364
Lots of praise to you, that's quite a project.
And does this mean now you have many grease smudges on your computer's keyboard, ha
KC
It worked well so far-everything is back together and no leaks, I am doing the rest of the 250 hour service shortly. I used a printout of what I got on tractorbynet so the grease and oil smudges are on the paper and shop manual only :)
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #365
Great that this all worked out well
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #367
Little bit of slope mitigation. 8yds of material.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #369
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #370
Well, that looks great. very clean lines
Thanks, all FEL work due to room constraints.
The customer didn’t want to go past the trees, I would have doubled the material and set it out further, lessening the slope even more, but it came out pretty well.
New/Unused 200lbs Cast Iron Anvil (A57454)
New/Unused 200lbs...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
(1) HD 25ft x 24ft Full Garage Kit Metal Building Frame (A57453)
(1) HD 25ft x 24ft...
Weiler P385 (A55272)
2015 Peterbilt 365 Quad Axle Altec AC45-127S 5 Section 45 Ton Crane Truck (A56858)
2015 Peterbilt 365...
Unused IRTPL 10,000lb Two Post Car Lift (A55272)
Unused IRTPL...
