MF 231S FEL external hydraulic problem
   / MF 231S FEL external hydraulic problem
I would take a close look at the front mounted Pump for Identification mine was a Vickers Vane pump many other tractors used gear pumps. maybe the Masseys front pump has good parts availability.
If you can get the #'s off the pump and who manufactured it we can start to look for either a new internal shaft or possibly a replacement pump if the price is right.
The spline clearance can be what causes the coupler failure. never had another problem with the 3000 once that was replaced.
It may also be cheaper to replace the pump complete if you can get the numbers/ brand off of the old one
Well it messed up first, it broke shaft near crankshaft. I put new pump on then. It stripped splines also. I used old pump because I didn稚 want to drill hole through new shaft of pump. I am not sure why splines keep stripping. I am not sure what u mean by splines clearance.
   / MF 231S FEL external hydraulic problem #22
By spline clearance he means, do the splines slide on snugly or once it is on does it have motion. In other words can you rotate one back and forth before the other one starts to move. Does it have "play" in it?
148in Roll Up Garage Door (A55852)
148in Roll Up...
2014 Kawasaki Mule 600 Utility Dump Cart (A55973)
2014 Kawasaki Mule...
Hose Reel (A55787)
Hose Reel (A55787)
Toro 880 Procore (A55758)
Toro 880 Procore...
2004 Ferrara Apparatus Pumper Fire Truck (A55852)
2004 Ferrara...
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
