MF 231S FEL external hydraulic problem
   / MF 231S FEL external hydraulic problem
I would take a close look at the front mounted Pump for Identification mine was a Vickers Vane pump many other tractors used gear pumps. maybe the Masseys front pump has good parts availability.
If you can get the #'s off the pump and who manufactured it we can start to look for either a new internal shaft or possibly a replacement pump if the price is right.
The spline clearance can be what causes the coupler failure. never had another problem with the 3000 once that was replaced.
It may also be cheaper to replace the pump complete if you can get the numbers/ brand off of the old one
Well it messed up first, it broke shaft near crankshaft. I put new pump on then. It stripped splines also. I used old pump because I didn稚 want to drill hole through new shaft of pump. I am not sure why splines keep stripping. I am not sure what u mean by splines clearance.
   / MF 231S FEL external hydraulic problem #22
By spline clearance he means, do the splines slide on snugly or once it is on does it have motion. In other words can you rotate one back and forth before the other one starts to move. Does it have "play" in it?
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2021 FREIGHTLINER...
2024 YANMAR TL100VS SKID STEER (A60429)
2024 YANMAR...
2019 FORD F-150 XL CREW CAB TRUCK (A59823)
2019 FORD F-150 XL...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
1991 Suzuki LT160 Quad Runner (A59814)
1991 Suzuki LT160...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
