/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #421
Not to pick on you but there really isnt any reason for removing safety equipment like the ROPS. I didnt catch that when I looked...thanks for pointing out. Going further I will not be acknowledging posts and threads where people posts things in an unsafe manner-like removing ROPS.
To each their own.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #422
To each their own.
I agree "To each their own" Rops would be ok IF the hinge wasn't up so high. Useless up as high as it is - can't clear overhead obstacles when need to.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #423
Here's me battling that buckthorn.
Yeh I agree, man.
KC, answering you, you know I did that seat upgrade so that I could just flip the seatback down and sit facing the backhoe. I was wanting to see how much easier it would be without the rops in the way. I must say, it was really nice, just raised my legs and spun around as you see in the video I made. But it just felt unsafe to not have the rops up, and also seems kinda dumb to remove that for the sake of a couple seconds literally of climbing over the seat. So they're back on.
Speaking of rops anyways, I keep forgetting to wear my seatbelt with it. Which leads me to my next point...doesn't that seat belt suck? It ratchets up with every bump and then I have to release it and put it back on. I'm wanting a seatbelt that doesn't ratchet, anybody swap for one, or find some other solution?
Thanks for explaining Gene.
I guess I never thought about that on my GC as I have a hard sided cab just inches in front of the ROPS.
The rear of the cab is open for backhoe operation using the seat and in the winter there is a clear plastic soft panel that Velcro's in place.
About the seat belt tightening up, it does not do that for me as I'm disabled and I go slow enough in areas of my property that I only rock a little back and forth.
KC
KC
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #425
GeneV, where did you get that seat. So much better than swiveling.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #427
Finally got the winch attached-too hot to do wiring today though. winch120200629_170634.jpg
Used two Badlands winch mounts back to back from HF
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #429
Finally got the winch attached-too hot to do wiring today though.View attachment 661515
Just be careful how you load winch, remember you only have a small battery and alternator.... Probably should add a volt meter to save getting caught out on back 40 with dead battery....
Dale
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
2001 Ford F150 (A50121)
2001 Ford F150...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
CATERPILLAR CS54B ROLLER (A52707)
CATERPILLAR CS54B...
