/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #421
Not to pick on you but there really isnt any reason for removing safety equipment like the ROPS. I didnt catch that when I looked...thanks for pointing out. Going further I will not be acknowledging posts and threads where people posts things in an unsafe manner-like removing ROPS.
To each their own.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #422
To each their own.
I agree "To each their own" Rops would be ok IF the hinge wasn't up so high. Useless up as high as it is - can't clear overhead obstacles when need to.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #423
Here's me battling that buckthorn.
Yeh I agree, man.
KC, answering you, you know I did that seat upgrade so that I could just flip the seatback down and sit facing the backhoe. I was wanting to see how much easier it would be without the rops in the way. I must say, it was really nice, just raised my legs and spun around as you see in the video I made. But it just felt unsafe to not have the rops up, and also seems kinda dumb to remove that for the sake of a couple seconds literally of climbing over the seat. So they're back on.
Speaking of rops anyways, I keep forgetting to wear my seatbelt with it. Which leads me to my next point...doesn't that seat belt suck? It ratchets up with every bump and then I have to release it and put it back on. I'm wanting a seatbelt that doesn't ratchet, anybody swap for one, or find some other solution?
Thanks for explaining Gene.
I guess I never thought about that on my GC as I have a hard sided cab just inches in front of the ROPS.
The rear of the cab is open for backhoe operation using the seat and in the winter there is a clear plastic soft panel that Velcro's in place.
About the seat belt tightening up, it does not do that for me as I'm disabled and I go slow enough in areas of my property that I only rock a little back and forth.
KC
KC
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #425
GeneV, where did you get that seat. So much better than swiveling.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #427
Finally got the winch attached-too hot to do wiring today though. winch120200629_170634.jpg
Used two Badlands winch mounts back to back from HF
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #429
Finally got the winch attached-too hot to do wiring today though.View attachment 661515
Just be careful how you load winch, remember you only have a small battery and alternator.... Probably should add a volt meter to save getting caught out on back 40 with dead battery....
Dale
Peterbilt (A51692)
Peterbilt (A51692)
2025 Kivel Bale Spear Skid Steer Attachment (A55851)
2025 Kivel Bale...
***Partial vin on frame*** Odo: 224045 (A55852)
***Partial vin on...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
2015 SKY TRAK 6036 TELEHANDLER (A56129)
2015 SKY TRAK 6036...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
