Pimp my 1526 exhaust ....
   / Pimp my 1526 exhaust .... #1
JerryK
Elite Member
Vanderbilt, Michigan, USeh?
Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154L (1991) Caterpillar E70B
Got tired of the 1526 spitting black krap on startup all over my front blade .. Procured me a stainless 1-1/2" O.D. weld elbow, drilled thru/installed a 10-32 stainless bolt, and now have stainless exhaust tip deflectors on two of my Mahindri... LIFE IS GOOD...!!!!!!!!!!!!!!!! :)
   / Pimp my 1526 exhaust .... #2
Think you'll get exhaust towards you now?
It now points sideways just in front of the left front tire. My 5035 points up behind the right front, and I don't seem to get any fumies there, and that tractor really snorts when you travel up hill at speed. 2555 has a cab, but that used to point right at where my previously yellow fuel cans were, and they got blasted. Fixed that with a tip, too. As far as diesel fumes, if it is running, and you are going in a direction that the wind blows it towards you...... there is absolutely no direction you can point it where there will be no fumes 100% of the time. Part of owning/running a diesel.
   / Pimp my 1526 exhaust .... #5
:thumbsup: . . . . .
   / Pimp my 1526 exhaust .... #6
I致e cut my exhaust off at the bend and pointed it down and inward. Basically the exhaust is blowing under the tractor to wards the right front wheel. I very rarely get any whiff of exhaust smoke now. However that doesn’t work on yours, because you have something on a subframe on the front. I also modified the battery holder bracket to fit a Group 34 AGM battery.
Sounds great. I am a firm believer that if you want to change something in your life, have at it. Keep up the good work ... !!!! :)
   / Pimp my 1526 exhaust .... #8
One of these days I'll be uploading a picture of it (if I don't forget it), ha!
   / Pimp my 1526 exhaust .... #9
Here is my exhaust modification.
   / Pimp my 1526 exhaust .... #10
Jerry,
Ya know, I have never seem any equipment of yours out getting dirty. You are always twicking something or adding something. How about some action shots out getting dirty?:duh:
hugs, Brandi
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2022 Can-Am Defender XT HD10 (A59814)
2022 Can-Am...
2007 Hyster S30FT 3,000lb. LP Forklift (A60460)
2007 Hyster S30FT...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2016 Ford Transit 350 Cargo Van (A59230)
2016 Ford Transit...
