Ed's 77 Terex 72-41 Wheel Loader
   / Ed's 77 Terex 72-41 Wheel Loader #401
Mountain guy whats the poop on the tow rig ? Thats a sweet beast.:thumbsup::drink:
   / Ed's 77 Terex 72-41 Wheel Loader #402
Looks pretty clean to me, don't see any poop on it :eek::
It is a 1964 International 1 ton 4WD. It has a 345 V8, 5 speed transmission with a 4 speed transmission mated behind it, factory 2 speed transfer case, Dana 70 front and Eaton dropout rear, Air locker front, Detroit locker rear, 41 inch tires, power steering, front and rear PTO winches, reinforced the body and frame in key points, on board air compressor and welder, body redone five years ago, lots of stuff powder coated.
Well Well, it's getting serious now.
Those look beefy.
Yes.
And yes.
I’ve been looking for a couple years, finally found one suitable. It’s hard to get logs into the bucket, they roll away. And they have to be short.
   / Ed's 77 Terex 72-41 Wheel Loader #408
:steeringwheel: So, . . . . 20 forward gears and 5 reverse?? Plus the 2 speed multiplier cuz of the transfer case. This set-up didn't increase your top speed at all, just major towing and crawling speeds, . . . correct? Very impressive.
I have not tried to figure it all out, it gives me a headache. All I know is I get more reduction when I want it, and I do not have the big gap between 3rd and 4th that the 5 speed overdrive is known for.
Correct.
Crawl ratios are 61:1, 113:1, 207:1, and 375:1.
   / Ed's 77 Terex 72-41 Wheel Loader #410
Correct.
Did you build that just for the Dusy Ershim trail?
I wish to run that thing one day, but you have to have such a built up rig to run it. I would have to ship my toyota out there and then back. It's a commitment for a Wyoming boy.
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
Heavy Duty Jumper Cables (A51694)
Heavy Duty Jumper...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
