Bucket looses curl pressure after some use
   / Bucket looses curl pressure after some use #11
Mine does the same intermittently and I have all brand new cylinders. Been told it is likely in the regenerative circuit of the SCV whatever that is. Hasn't done it in a while but I was told to try cycling the curl back and forth a few times and that seems to fix the problem.
I have seen some tractor OEM cylinders with a simple Buna rubber oring/backup for an internal piston seal. IMHO Very poor excuse of a piston seal from factory equipment. In this situation we have had great success changing to a polyurethane type seal that can handle higher pressures, heavy duty and still fit in the same seal groove.
Is that what the replacement kit from JD will have or should I look for an aftermarket kit?
   / Bucket looses curl pressure after some use #13
John Deere makes good kits, I was thinking out loud about other manufacturers.
Thanks, i found the kits at the dealer and a shop locally that will do the swap at $150 per cylinder. Is that charge ok?
   / Bucket looses curl pressure after some use #15
$150 sounds reasonable for a repack assuming they stand behind their work.
   / Bucket looses curl pressure after some use #17
It's a 30 minute job after you have the tools and experience. Took me and my SIL about an hour maybe hour and a half to figure out the first one. You Tube is your friend.
NEW Wolverine 36'' Skid Steer Grapple Bucket (A53002)
NEW Wolverine 36''...
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A52748)
2018 Rock Solid...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
