Bucket looses curl pressure after some use
   / Bucket looses curl pressure after some use #11
Mine does the same intermittently and I have all brand new cylinders. Been told it is likely in the regenerative circuit of the SCV whatever that is. Hasn't done it in a while but I was told to try cycling the curl back and forth a few times and that seems to fix the problem.
I have seen some tractor OEM cylinders with a simple Buna rubber oring/backup for an internal piston seal. IMHO Very poor excuse of a piston seal from factory equipment. In this situation we have had great success changing to a polyurethane type seal that can handle higher pressures, heavy duty and still fit in the same seal groove.
Is that what the replacement kit from JD will have or should I look for an aftermarket kit?
   / Bucket looses curl pressure after some use #13
John Deere makes good kits, I was thinking out loud about other manufacturers.
Thanks, i found the kits at the dealer and a shop locally that will do the swap at $150 per cylinder. Is that charge ok?
   / Bucket looses curl pressure after some use #15
$150 sounds reasonable for a repack assuming they stand behind their work.
   / Bucket looses curl pressure after some use #17
It's a 30 minute job after you have the tools and experience. Took me and my SIL about an hour maybe hour and a half to figure out the first one. You Tube is your friend.
Fuel Tank (A51573)
Fuel Tank (A51573)
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2020 COLOMBO TM LOT NUMBER 216 (A53084)
2020 COLOMBO TM...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
