Bucket looses curl pressure after some use
   / Bucket looses curl pressure after some use #11
Mine does the same intermittently and I have all brand new cylinders. Been told it is likely in the regenerative circuit of the SCV whatever that is. Hasn't done it in a while but I was told to try cycling the curl back and forth a few times and that seems to fix the problem.
I have seen some tractor OEM cylinders with a simple Buna rubber oring/backup for an internal piston seal. IMHO Very poor excuse of a piston seal from factory equipment. In this situation we have had great success changing to a polyurethane type seal that can handle higher pressures, heavy duty and still fit in the same seal groove.
Is that what the replacement kit from JD will have or should I look for an aftermarket kit?
   / Bucket looses curl pressure after some use #13
John Deere makes good kits, I was thinking out loud about other manufacturers.
Thanks, i found the kits at the dealer and a shop locally that will do the swap at $150 per cylinder. Is that charge ok?
   / Bucket looses curl pressure after some use #15
$150 sounds reasonable for a repack assuming they stand behind their work.
   / Bucket looses curl pressure after some use #17
It's a 30 minute job after you have the tools and experience. Took me and my SIL about an hour maybe hour and a half to figure out the first one. You Tube is your friend.
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
ITEM LOCATION (A53084)
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A52748)
PENDING SELLER...
