/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #521
Good day to clear my mind and dig this old trench and put in 12" culvert. This at the bottom of the lawn and the run off was leaving rocks and unmowable so this was my fix. The only weight I'll ever have in it is a mower or my scut so I wasn't worried about doing the base as if it was a driveway culvert.
12" was a bit overkill for 98% of the storms but I wanted to be sure it'd handle the "gully washers"
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #522
The old mercury stick (thermometer ) hit the triple digits today so I decided to stay indoors.... Supposed to go higher the next few days so tractor will probably stay in shed unless I do some early morning work....
Dale
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #523
Man... Had a great day on brush hog rebuild progress! Can't wait to slap this thing back on the GC and cleanup some roadsides that get neglected around here and create accidents. Speaking of the GC1710...it does a great job of doubling as a break bench lol. I used the FEL as a clamp point to bend the flange for the side panels.IMG_20200816_171833.jpgIMG_20200816_171841.jpgIMG_20200816_172215.jpg
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #524
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #525
View attachment 666327View attachment 666329
Man, nice!
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #527
10” excavation for a concrete patio yesterday dig and hauled the spoils.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #528
Dropped a bunch of dead trees and donated the pines to the neighborhood bon fire.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #530
Couple of grading projects, 2 different yards, same family. Mostly tiller and FEL work.
The second yard I had to establish a shallow swale.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #531
How the first one started
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #533
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #534
You’re basically rebuilding the whole deck?
Yes. I will have reused the gearbox (which I'm rebuilding with new seals and bearings), drive shaft, tail wheel, and the front and rear metal bands of the original brush hog. I completely refabricated the sides, top, hitch points (making it QH compatible) frame and the wheel bracket.
Edit: I've modified the design quite a bit because of the way the original failed
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #535
Very nice, I look forward to seeing the finished product.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #536
Nice Mower project cg.
MoMower - you do good work!
My tractor has been doing log hauling and tree cutting duty for the past few weeks-hope to get some time soon for some clearing and trail building,
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #537
Thanks Ken, I usually shut the business down for the winter, the end of October, then I will get on my trail building at home.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #538
So I've completely rebuilt the gearbox with cups, bearings and seals. Given that the bottom seal was toast and the bearing wobbled out and the sleeve worn out they had the gearbox full of heavy grease which had to be scraped and scrubbed and cleaned out. I also had to improvise fixing the bottom cup and was able to add a stainless steel sleeve and drive the cup down into it. I shouldn't be surprised a 60+ year old gearbox is that worn out
And now the reason I'm on a GC thread telling you about this. I was also able to test fit the brush hog to the GC. She lifted it without a second thought...of course. LOL. I swear I heard the tractor ask me to hurry up and finish this thing already so we could go thrash some grass but that might have been my imagination.
I hope to get to paint stage later this week after building the front/back supports and tail wheel swing arm/bracket.IMG_20200830_134604.jpgIMG_20200831_204312.jpgIMG_20200831_204319.jpgIMG_20200831_204337.jpgIMG_20200831_211946.jpg
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #539
Starting to look like a bush hog being built-nice
Looking forward to seeing your finished brush hog completed, painted, and tested out.
Great work!
KC
John Deere 4044M (A60462)
John Deere 4044M...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
JCB 509-23TC TOOL CARRIER TELESCOPIC FORKLIFT (A60429)
JCB 509-23TC TOOL...
iDrive TDS-2010H...
32in. Tilting Bucket Mini Excavator Attachment (A59228)
32in. Tilting...
