By pass of seat safety switch - pro's & con's
   / By pass of seat safety switch - pro's & con's #22
Paying attention, being careful, experience, it all helps prevent accidents. Any one can have a moment when things go wrong. Unforeseen circumstances, equipment failure, holes, light stroke, to much heat, to many to list and probably could not thing of a fraction of the possible problems.
We all have to decide what the risk level is that we wish to deal with. Most of us have never made the paper or obits. Those that have made the paper and obits were also operating at the risk level they felt comfortable with. You can google tractor accidents and many will be from improper operating. Many are equipment failures, such as safety items not working or being used as intended. Things happen. Best of luck to each and everyone, and their loved ones, with the choices made.
   / By pass of seat safety switch - pro's & con's #23
i never minded the seat switch on my old JD870 because they had a built in bypass...lift seat, pull out switch plunger. you used this when operating pto equipment while off of tractor such as a log splitter. but if you sat on seat, it depressed plunger back to normal use. now on my new cab tractor there are no seat switches...only a neutral and pto switch. they figure you wont fall out of a cabbed tractor and get run over. i hate seat switches, but never disabled mine because i was afraid the clumsy wife or someone else could get hurt. by no means am i a safety police person...i hate most of these warning devices. such as the sticker on my wifes blender that stated do not use in shower. saw.jpg sign 2.jpeg sign 3.jpg haha.jpg haha2.jpg
   / By pass of seat safety switch - pro's & con's #24
No graphic pictures, please.
don't worry, I won't!. I did find a site months ago that had all kinds of accident pictures that would shock anybody!. I wish I hadn't looked at it, it's something you just can't forget.:shocked:
   / By pass of seat safety switch - pro's & con's #25
I seriously can't think of a good reason to get off the seat while the tractor is in gear!. if it's in gear, the tractor SHOULD shut down if you get off the seat!. common sense!..
   / By pass of seat safety switch - pro's & con's #26
for a geared tractor, yes. but how about an HST. i stand on ground and move my tractor back and forth with peddle to hook up implement. that being said, i did have a startle last week. the HST return spring popped off while operating in heavy brush. its quite a start to have the tractor keep going after i lifted my foot off of the peddle. all i had to do was quickly press the reverse till it hit center, but if that happened to the wife, it might have been different. im going to instruct her about possibility this weekend. im going to also try to fabricate a shield to prevent this from happening again. first time in 10 years it happened.
   / By pass of seat safety switch - pro's & con's #27
Not really. Some times you have to stand up for various things. I, for one, have to stand up lots of times when I'm tilling the orchards. I need to push the branches away so I don't break them. Other times I have to stand up to see the tip of the forks. The list goes on and on. Another one is, since my have tractor has an open platform, when I'm doing long runs on mowing or tilling, I just stand up to stretch my legs a little bit, but I do have a mid mounted ROPS which provides a good handle.
   / By pass of seat safety switch - pro's & con's #28
anti-scald valves
Anti-scald valves, like seat switches, are moronic wussie things, to try to protect people from their own stupidity !
   / By pass of seat safety switch - pro's & con's #29
ya, the forks are a good reason to stand up while moving. i have to just about cram my head into cab roof to see forks when loading a generator pallet. would definitely hate engine to shut off
   / By pass of seat safety switch - pro's & con's #30
My 93 year old father in law with dementia and a bunch of little kids would beg to differ. ;)
2015 MACK CXU613 (A52472)
2015 MACK CXU613...
CAT Skid Steer Grapple (A51573)
CAT Skid Steer...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2012 John Deere 7280R MFWD Tractor (A52748)
2012 John Deere...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
