Using rear remotes for grapple - as simple as I think?
   / Using rear remotes for grapple - as simple as I think? #21
Lets put it this way, If someone GAVE me a 3rd function kit, I would not install it for it. I would sell the kit and keep my current setup. Yes, it is actually that convenient to use with the extended control lever I fashioned. It also has one other advantage in that I can easily "feather" the grapple pressure. Handy at times to pick up softer things I don't want to crush like a rotten limb for instance. I can also easily adjust the closing speed. AS my pump is pretty healthy and the cylinder of my grapple is pretty small, you can snap the grapple shut with a bang, or slow as you want. While I always considered my original installation a stop gap measure until I got up enough money for a 3rd function, now I would not trade it out at all. I am one happy ole curmudgeon. :)
yeah- i bet several of us using the rear remotes don't miss having our grapples slam closed or open :D
no finesse in a 3rd function without restricting flow likely at extra expense.
   / Using rear remotes for grapple - as simple as I think? #22
I made an extension for my non detent rear remote about 10 years ago for use with my front snowblower. Just slips on. I left the other remote with detent fir wood splitter. I also routed s set of hoses under tractor with disconnect right next to loader disconnects so i could easily remove loader. Have bracket up by bucket. Id post pics, but i cant get this ipod to post pics tonight.....i hate apple sometimes. My extension is like james.
https://www.tractorbynet.com/forums/kioti-buying-pricing/288874-kioti-hydraulics-what-do-i.html
   / Using rear remotes for grapple - as simple as I think? #23
I have true third function on the Branson. I added a three spool loader valve to my Kioti. It is nice being able to feather the grapple on the Kioti. However, I don't mind the way it operates on the Branson. Very little difference between the two setups.
   / Using rear remotes for grapple - as simple as I think? #24
I don't have any problem controlling my Grapple using electric over hydraulic true 3rd function. I use all three of my rear remotes for their original intent.
I'm glad to see owners improvise and make what they have function efficiently.
   / Using rear remotes for grapple - as simple as I think? #25
When I bought my tractor, I knew I would be using the grapple a lot. The dealer offered a 3rd function for $900 or hoses to the rear remotes for $250. I estimated I would use the tractor for the next 15 years...God willing. $650 over 15 years worked out to just over $43/year. For me, it was and easy choice, as I would need to move my hand every time I used the grapple.
It appears you will be using your grapple a lot. Like overszd said, it becomes a personal choice.
   / Using rear remotes for grapple - as simple as I think? #26
When i bought mine, dealer could not locate an instock 3rd function anywheres that he could get in a reasonable time, and i needed tractor right away. Not wanting to haul it back later, i opted for using the 2nd remote and he removed the detents for free and fashioned up the hoses and front mount for $200.
   / Using rear remotes for grapple - as simple as I think? #27
I also used James k0ua extension lever mod for my DK40 and it works like a charm.
   / Using rear remotes for grapple - as simple as I think? #28
I gotta fess up.....I stole the idea from grsthgreat and Murph. It was not an original idea of my own.... gotta give credit where credit is due.
   / Using rear remotes for grapple - as simple as I think? #29
That's odd;I can stop my third function grapple in any position(Kubota factory set-up)
2009 Ford F-250 Pickup Truck, VIN # 1FTSX21Y49EA41686 (A48836)
2009 Ford F-250...
2022 Case IH Steiger 470HD AFS Connect Quadtrac 4WD Tractor, (A50657)
2022 Case IH...
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
2011 KENWORTH T800 SLEEPER (A50854)
2011 KENWORTH T800...
Pallet of Pulleys/Hooks/Come Along (A50860)
Pallet of...
2014 Audi A4 Sedan (A48082)
2014 Audi A4 Sedan...
