DYI fume extractor ideas
   / DYI fume extractor ideas #11
Just for what it's worth. Would be no good for MIG.
That seems like a really nice surface to be welding on.
   / DYI fume extractor ideas #12
Gene, a couple of suggestions. Not sure what your neighbor situation is but you might want to consider moving your shopvac outside and add a remote switch. That noise would drive me crazy in short order.
   / DYI fume extractor ideas #13
Yes you do need more CFM's for exhausting fumes, and I had to put ear plugs in to watch your welding video, ha.
KC
   / DYI fume extractor ideas #14
When absolutely needed I use the same shop vac idea but I have beastly vac with with a 3.5" hose. I don't use a filter and sparks are out ( I hope ) by the time they get outside where the vac sits. Instead of a remote switch I just have a cord running in under the overhead and just plug in when welding. It's pretty effective and yet I seldom use it. It takes a bit to get it set up and the small projects are done by the time I would get it set up and the bigger projects would require a lot of moving it around. There's no good way on the cheap unless you are patient and forgiving. Good Luck !
   / DYI fume extractor ideas #15
A bigger "hood" and bigger vac will make it quite effective actually if you can set the hood up right where you are welding. I have a smoke alarm about 18' away and it doesn't set it off. But as the others said I hate the noise and it is a tight area not really good for welding so I only use it when I have to in the middle of winter. I remove the filter from the vac and place a cake pan of water in the bottom. I use a foot switch to turn on and off. I also stay down there for a half hour min after I am done welding just to make sure. Never thought of putting the vac outside - that is a super idea. Wonder if it will run at 20 below....
gg
Naw, I don't have a mig, just stick. Had a flux core too, I sold it.
Ha, that's what I did at first! That rocket vacuum cleaner you can catch a glimpse off in the video, that's what I used at first, and I just stuck it out the window and ran the sump pump hose from it. I had 2 problems, first the longer hose made a ton of whistling noise, it was so annoying! And then...it started raining. :shocked:
KC
Here's my other idea. This fella uses a 4" vent fan, says it works ok for welding fumes if he puts the hood close. I'm thinking of using a 6" fan, it's moves like 200 cfm's.
Do you have it enclosed outside, what do you do about rain and stuff?
gg
Oh that's a bigazz hood, yeh that's a great idea! The vacuum noise is annoying though, I'm with you right there. I'm curious what a 6" duct fan would sound like, that's where I'm starting to look with this fume exhaust thing.
2006 Sterling Acterra Rollback Wrecker Truck (A59814)
2006 Sterling...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56438)
PENDING SELLER...
LIGHT TOWER (A56857)
