Light bar
   / Light bar #1
fishfrank
Member
Is it possible to add a light bar to the ROPS and tie into the headlight wiring using the factory switch to operate them? I would leave the factory headlights unplugged since they are pretty much useless to me. I’m dumb on electrical things. It’s a DK40SE
   / Light bar #2
Possible, yes. Practical, maybe. You need to take into consideration the current draw of the proposed light bar and the current capability of headlight circuit and wiring. Additionally you should not drill any holes in the ROPS. Use clamps or U bolts instead.
   / Light bar #3
Plus, most Light bars come with its own wiring already setup. Relay, switch, fuse, etc. All you need to do is trim the wires to suit your needs. Hook the red wire to the battery positive, the black to the negative and you're good to go.
   / Light bar #5
Just tap directly into the main 12v line or battery, install your own switch and fuse, and then route directly to the LED Bar. Clamp those bars, no drilling of any type, which could weaken the ROP. Also consider switching your low performance headlight bulbs out for the newer high performance LED bulbs. Then you can get good lighting from both your headlights and the ROP light bar. Consider buying a low cost volt meter from say Walmart or Ace hardware, to confirm 12V connections as you work on the install.
   / Light bar #6
I cannot comment of your Kioti's set-up, however...
My 4105 has a pre-installed light 'jack' (bullet type, male/female) behind the seat, just above the PTO. It is pre-wired and fused to the light selector switch, 4th position.
I installed a lightbar underneath the ROPS, ran a 2-wire 'cable down to the jack (tie-wrapped along the ROPS), soldered male/female bullet ends on the wire (purchased from a local auto parts shop, along with the wire). All works well.
Ask your Dealership if a similar auxiliary jack is present. Mine showed me exactly where it was.
   / Light bar #7
If using LED I’d expect you’d have no issues splicing into your headlight wiring and of course you’ll need a ground.
LED’s have such low draw. Particularly compared to your headlights.
compare total wattage
Most important as noted no drilling rops ever.
Joel
   / Light bar
Joel
This is what I was thinking as well. I have seen other posts about wiring a lightbar and wondered why you cant just disconnect the headlights and tap into that. I have a grill guard on the front that ,between it and the FEL, makes the stock headlights useless.
   / Light bar #9
I found an unused 3 pin connector in a cable harness running across the back above the top link. It had a ground, 12v always on, 12v switched (on when running). I purchased a switch that fit in a blank position beside the seat and wired in with a fuse holder. I made a bracket for the light, but others have used strong magnets attached under the ROPS cross bar.
   / Light bar #10
It's always best to instal a lighting relay and switch the control line to the relay rather than the +v wire. Be sure to put a fuse or breaker in the +v wire near the battery. Many lightbars come with a relay, switch and wire harness ready to go, though you will probably need the wire to the ROPS to be extended.
I have a 32" dual row lightbar from Caliraisedled on my pickup behind the lower grill that puts out a lot of light and is a great deal for the price. Mine uses 60 Osram LEDs, so it draws 300 watts, which is 3 times what a pair of headlights burn, and probably 10 times the light output. It's harsh light, cold and bluish, and probably more lumens than I would want on the tractor where you're not looking to the far distance. There are warmer ones out there, with some or all of the LEDs having an amber lens. You can buy 14" or 22" ones, and Caliraised has a single row amber 150 watt one that looks about right to me for a working light. Get a flood or combo rather than a spot beam light,
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2020 Ram Promaster City 1500 Cargo Van (A59230)
2020 Ram Promaster...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
Dodge Charger (A56859)
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
