DYI fume extractor ideas
   / DYI fume extractor ideas #41
I hate the sound of leaf blowers even more than shop vacs.:mad:
   / DYI fume extractor ideas #42
Especially if it isn't you on the other end of the blower! I have a couple shop vacs and pretty much my top buying criterion is dB level.
See also my thread on trying to quiet my shop air compressor. I hate noise... and wind.
   / DYI fume extractor ideas #43
Na! Nothing worse than a pissy little 4 stroke gas engine running at 3600! Along with that horrible metalic pinging sound something inside them makes!
   / DYI fume extractor ideas #44
I think the key is to try to design a large diameter duct/fan that moves the volume but not at too high of velocity. Seems 6in is minimum and 8in would be a premium for a home shop for a dedicated fume extractor. Again, wanting volume extraction without sucking the shielding gas and at a low dB level. At least this is my thinking.
I'm sure you're right about the shielding gas. I'm not an expert in fluid mechanics, but I'm thinking if you just expand the duct size from 3" (or whatever the leaf blower nozzle is) to 8" right before the fume extraction point, the air will be moving at the same CFM but lower velocity. And that megaphone we just made will probably amplify the sound, too.
I think some testing is in order. I'll see if I can locate my jerry-rigged leaf blower sometime later this week if I have time.
   / DYI fume extractor ideas #45
where is this thread about quiet compressors? I am also passionate about this topic. Here is the compressor I built.
   / DYI fume extractor ideas #47
I dont care about my generators noise, but my air compressor dies drive my nuts. Now thats noisy.
   / DYI fume extractor ideas #48
If you want to use it for reference, my fume extractor has approx a 6in duct and is rated at 780cfm.
I like that it doesn't blow all my warm air out in the winter, and hopefully my a/c next summer!
The duct is designed to be relatively close to the work peice, but won't effect the shielding gas. 1081777692.jpeg
   / DYI fume extractor ideas #49
The duct is designed to be relatively close to the work peice, but won't effect the shielding gas.View attachment 669687
Thanks TMGT... sound like I am pretty much on target. I'm thinking if I can port the noise to the exterior, I have something.
Dragoneggs, I'll hit your linked thread with more details, but real quick here...to dampen down noise in my shop, I used acoustic blankets, the kind used in sound studios.
2016 Genie S-45 4x4 45FT Telescoping Boom Lift (A50322)
2016 Genie S-45...
2000 INTERNATIONAL 4700 (A52472)
2000 INTERNATIONAL...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2018 KENWORTH T680...
2012 Ram 1500 Crew Cab Pickup Truck (A50323)
2012 Ram 1500 Crew...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
