Price Check Money Man Says We're Almost There. . .
   / Money Man Says We're Almost There. . . #31
Mine is the 60'' single lid. They also have double lids.
As you can see in the pics...I reclaimed a 7 acre overgrown pasture with this one and dug up those two rocks out of that pasture
Some like the long bottom double lid.
Call travis and tell him your intensions and he'll help you decide
   / Money Man Says We're Almost There. . . #33
I am sure EA, Land Pride, etc make great grapples but they are pricy. I had a Wild Kat grapple on my last tractor for ten years with no problems. I have an MTL on my current tractor and it has performed well at less than a third of the price of a Land Pride. I use a grapple a lot to push up trees and move brush, trees, etc. I do not have to deal with rocks. If your use will be brush you can save funds and get a good grapple at a reasonable price.
   / Money Man Says We're Almost There. . . #34
Yep......my 60" E-series root grapple has been shipped, and tracking shows arrival in two more days.
$1,152 delivered, From Mid-State Attachments in Denton, NC.
Long lower tines (not cross connected), and 52" opening.
My use is for brush and vines only, with not a rock for 10+ miles around.
I have two EA attachments, but their grapples are very pricey, and none of their tine designs would work well for my application.
   / Money Man Says We're Almost There. . . #35
yep they are pricy, but they are made with some of the best steel. And, USA BUILT. No cheap heavy chinese stuff
   / Money Man Says We're Almost There. . . #36
yep they are pricy, but they are made with some of the best light weight steel on the planet. And, USA BUILT. No cheap heavy chinese steel which takes away from your lift capacity
Why buy an expensive tractor, then worry about the cost of quality USA built attachments ?
   / Money Man Says We're Almost There. . . #37
"Best steel"..... does not have priority over the utility of an effective grapple tooth design for my needs.
Mid-State Attachments are BUILT in the USA,.........Denton, NC!
Should I have bought an EA grapple that would not meet my grapple design needs, simply because it was built by EA?
Would anyone buy a dump truck, when their application requires a pickup?
   / Money Man Says We're Almost There. . . #38
Would you buy a dump truck, when you need a pickup?
When is are grapple arriving soon I hope........:D
   / Money Man Says We're Almost There. . . #39
When I was shopping for both my grapples, I found there are several brands built in North Carolina. I would imagine NC and tractor implements is like Missouri and trailers with several small manufacturers is in area that steal designs and employees from one another.
   / Money Man Says We're Almost There. . . #40
Because I bought my tractor intending to keep it for years while implements area going to get beat up. If I bend or break an implement I throw it on a trailer and take it to a welding shop. I used my last cheap grapple hard for ten years and it half up. My BIL bought the tractor with grapple and continues to use it.
I’m not saying the OP should buy a cheap grapple but there are less expensive options depending on his uses.
2007 Volvo VNL Truck Tractor (A55315)
2007 Volvo VNL...
2003 Chevrolet 1500 Silverado Crew Cab Pick-up Truck (A55852)
2003 Chevrolet...
PumpJack Brand Pump Jack (A55315)
PumpJack Brand...
2015 Ford Transit 250 Cargo Van (A55852)
2015 Ford Transit...
1647 (A57192)
1647 (A57192)
Two Post Car Lift (A50120)
Two Post Car Lift...
