Traction Tire Swap - R-14 Versa Turf In - R-4 Out
   / Tire Swap - R-14 Versa Turf In - R-4 Out #61
Nice update. Thanks
   / Tire Swap - R-14 Versa Turf In - R-4 Out #62
I didn't know until after I bought my tractor about versa turfs. I am not disappointed about it and it wasn't an option to upgrade them when I bought it. I did the tire grooving thing and I have tremendous traction with the R4s and I think better than my last tractor with the turf tires in the snow. I have hills I mow and the R4s have thicker sidewalls so it helps to keep the tractor from squiggling around on those side slopes.
   / Tire Swap - R-14 Versa Turf In - R-4 Out #63
did u do it yourself? if so what tool did you use?
   / Tire Swap - R-14 Versa Turf In - R-4 Out #64
Yes I did it myself and it isn’t that hard to do, just take your time. I used an Ideal Tire Groover. I found it on eBay used for $10 plus $5 shipping. Usually they have a 1/4” cutting blade but this one has a 3/16” knife head. Bought some new blades for it for $7 on eBay as well. It’s is an older tire groover but it works and looks like new after cleaning it up.
   / Tire Swap - R-14 Versa Turf In - R-4 Out #65
What's a groover look like?
And -- thanks for the update on the Versa-Turfs!
   / Tire Swap - R-14 Versa Turf In - R-4 Out #66
thats a **** of a deal, they are over 100 new. used is 80, do you have pics of the tires?
   / Tire Swap - R-14 Versa Turf In - R-4 Out #67
051F96D9-0A81-4B05-8265-FE4FEAD9BA38.jpeg3D49B9D8-59EC-4440-865B-204DFCC24920.jpegC19EAE66-77B4-4065-B1BF-FB3A96C798CA.jpeg
Rear grooved tire, Older Ideal Tire groover and then the front tire grooved.
   / Tire Swap - R-14 Versa Turf In - R-4 Out #68
So it's heated! What, a combination of melting/cutting? Thanks for the pic; I'd never seen one of those before.
   / Tire Swap - R-14 Versa Turf In - R-4 Out #69
   / Tire Swap - R-14 Versa Turf In - R-4 Out #70
that looks awesome, how many blades did you go through? how much of a increase would you say you gained, i did my first snow plowing last night and with 4x4 and diff lock and loaded tires and a backhoe hanging off the back i was still sliding all over the place.
well i bought one for 85 bucks #4 blade.
CLUB CAR (A55758)
CLUB CAR (A55758)
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
(2) 42" HANG ON FORKS (A54757)
(2) 42" HANG ON...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
ARBOR PRESS (A57192)
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
