Traction Tire Swap - R-14 Versa Turf In - R-4 Out
   / Tire Swap - R-14 Versa Turf In - R-4 Out #61
Nice update. Thanks
   / Tire Swap - R-14 Versa Turf In - R-4 Out #62
I didn't know until after I bought my tractor about versa turfs. I am not disappointed about it and it wasn't an option to upgrade them when I bought it. I did the tire grooving thing and I have tremendous traction with the R4s and I think better than my last tractor with the turf tires in the snow. I have hills I mow and the R4s have thicker sidewalls so it helps to keep the tractor from squiggling around on those side slopes.
   / Tire Swap - R-14 Versa Turf In - R-4 Out #63
did u do it yourself? if so what tool did you use?
   / Tire Swap - R-14 Versa Turf In - R-4 Out #64
Yes I did it myself and it isn’t that hard to do, just take your time. I used an Ideal Tire Groover. I found it on eBay used for $10 plus $5 shipping. Usually they have a 1/4” cutting blade but this one has a 3/16” knife head. Bought some new blades for it for $7 on eBay as well. It’s is an older tire groover but it works and looks like new after cleaning it up.
   / Tire Swap - R-14 Versa Turf In - R-4 Out #65
What's a groover look like?
And -- thanks for the update on the Versa-Turfs!
   / Tire Swap - R-14 Versa Turf In - R-4 Out #66
thats a **** of a deal, they are over 100 new. used is 80, do you have pics of the tires?
   / Tire Swap - R-14 Versa Turf In - R-4 Out #67
051F96D9-0A81-4B05-8265-FE4FEAD9BA38.jpeg3D49B9D8-59EC-4440-865B-204DFCC24920.jpegC19EAE66-77B4-4065-B1BF-FB3A96C798CA.jpeg
Rear grooved tire, Older Ideal Tire groover and then the front tire grooved.
   / Tire Swap - R-14 Versa Turf In - R-4 Out #68
So it's heated! What, a combination of melting/cutting? Thanks for the pic; I'd never seen one of those before.
   / Tire Swap - R-14 Versa Turf In - R-4 Out #69
   / Tire Swap - R-14 Versa Turf In - R-4 Out #70
that looks awesome, how many blades did you go through? how much of a increase would you say you gained, i did my first snow plowing last night and with 4x4 and diff lock and loaded tires and a backhoe hanging off the back i was still sliding all over the place.
well i bought one for 85 bucks #4 blade.
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
2017 Ford F-550 Enclosed Service Truck (A53422)
2017 Ford F-550...
UNUSED FUTURE MINI EXCAVATOR HYD THUMB CLAMP (A57193)
UNUSED FUTURE MINI...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A57024)
2016 KBH...
(8) 12" CHANNEL IRON (A57192)
(8) 12" CHANNEL...
(15) 1 RANCH 1RGPM GROUND PROTECTION MATS (A57193)
(15) 1 RANCH 1RGPM...
