Log Splitter - How often tot change fluid and filter?
   / Log Splitter - How often tot change fluid and filter? #21
I had to remove the filter system from my splitter. It was on the return side but when I would jog the lever back and forth trying to get an oak to split, The filter would blow up. Splitter is a Northern Tool and it came with no filter. ???
Does it have a suction line strainer threaded into the tank?
   / Log Splitter - How often tot change fluid and filter? #22
Found manual on line my unit....It says to keep hydraulic fluid 1 inch below top of tank.... Guess it leaves room for expansion...
Dale
Best answer Ever!!! Stop the STRESS!!!
   / Log Splitter - How often tot change fluid and filter? #23
It has a separate fill fitting so I'm not sure if there is a strainer where the return hose hooks up. I haven't had that end off. I'll have to check.
   / Log Splitter - How often tot change fluid and filter? #24
Probably a plugged filter with no bypass valve. Put s new filter on and it should be fine.
Aaron Z
   / Log Splitter - How often tot change fluid and filter? #25
The suction line strainers offered for my hydraulic reservoir (different sizes depending on the flow rate, in gallons per minute) , is a separate fitting, it's located where the supply line, that goes to the hydraulic pump attaches.
No by-pass valve, in the " filter assembly", you used, sounds like a good explanation for the filter explosion. However, The spec sheet on a filter head of the same size as my filter head talks about by-pass capabilities (couldn't find a data sheet on-line for the exact head I used), to confuse matters, the technical data for the spin on filter
I used, claims a working pressure of 175 psi but only 75 psi max, if non-bypass! Does the by-pass happen only in the filter head or the just the filter? My filter head and filter can as a package from the manufacturer.
   / Log Splitter - How often tot change fluid and filter? #26
Both are available, most auto oil filters have a bypass built in. Other filters vary.
Aaron Z
   / Log Splitter - How often tot change fluid and filter? #27
Aaron Z
I bought the filter and assembly from a farm store. i'm sure it has a bypass built in to the housing. I posted this on another site and a guy said that I can't pump the splitter handle while stuck in a piece of wood or the filter would blow. It did and it was new. Does this make sense? I' betting everyone with a splitter pumps the handle when the going gets tough.
   / Log Splitter - How often tot change fluid and filter? #28
The governor on my gas engine doesn't always pick-up the speed when the going gets tough, so I give it more gas using the throttle (before it stalls). Still playing around with the governor, to get it working properly. Only a couple of seconds of it running faster, solves the problem, with the throttle spring returning to the engine speed to the normal set speed.
   / Log Splitter - How often tot change fluid and filter? #29
It doesn't make sense to me. Ours doesn't do that.
Aaron Z
   / Log Splitter - How often tot change fluid and filter? #30
I don;t "pump" the handle. The governor should kick in when the motor starts to bog down.
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2016 Chrysler 200 Sedan (A50324)
2016 Chrysler 200...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
TAKEUCHI TB235-2 EXCAVATOR (A51242)
TAKEUCHI TB235-2...
2001 DITCH WITCH JT1720 DIRECTIONAL DRILL (A51242)
2001 DITCH WITCH...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
