Log Splitter - How often tot change fluid and filter?
   / Log Splitter - How often tot change fluid and filter? #21
I had to remove the filter system from my splitter. It was on the return side but when I would jog the lever back and forth trying to get an oak to split, The filter would blow up. Splitter is a Northern Tool and it came with no filter. ???
Does it have a suction line strainer threaded into the tank?
   / Log Splitter - How often tot change fluid and filter? #22
Found manual on line my unit....It says to keep hydraulic fluid 1 inch below top of tank.... Guess it leaves room for expansion...
Dale
Best answer Ever!!! Stop the STRESS!!!
   / Log Splitter - How often tot change fluid and filter? #23
It has a separate fill fitting so I'm not sure if there is a strainer where the return hose hooks up. I haven't had that end off. I'll have to check.
   / Log Splitter - How often tot change fluid and filter? #24
Probably a plugged filter with no bypass valve. Put s new filter on and it should be fine.
Aaron Z
   / Log Splitter - How often tot change fluid and filter? #25
The suction line strainers offered for my hydraulic reservoir (different sizes depending on the flow rate, in gallons per minute) , is a separate fitting, it's located where the supply line, that goes to the hydraulic pump attaches.
No by-pass valve, in the " filter assembly", you used, sounds like a good explanation for the filter explosion. However, The spec sheet on a filter head of the same size as my filter head talks about by-pass capabilities (couldn't find a data sheet on-line for the exact head I used), to confuse matters, the technical data for the spin on filter
I used, claims a working pressure of 175 psi but only 75 psi max, if non-bypass! Does the by-pass happen only in the filter head or the just the filter? My filter head and filter can as a package from the manufacturer.
   / Log Splitter - How often tot change fluid and filter? #26
Both are available, most auto oil filters have a bypass built in. Other filters vary.
Aaron Z
   / Log Splitter - How often tot change fluid and filter? #27
Aaron Z
I bought the filter and assembly from a farm store. i'm sure it has a bypass built in to the housing. I posted this on another site and a guy said that I can't pump the splitter handle while stuck in a piece of wood or the filter would blow. It did and it was new. Does this make sense? I' betting everyone with a splitter pumps the handle when the going gets tough.
   / Log Splitter - How often tot change fluid and filter? #28
The governor on my gas engine doesn't always pick-up the speed when the going gets tough, so I give it more gas using the throttle (before it stalls). Still playing around with the governor, to get it working properly. Only a couple of seconds of it running faster, solves the problem, with the throttle spring returning to the engine speed to the normal set speed.
   / Log Splitter - How often tot change fluid and filter? #29
It doesn't make sense to me. Ours doesn't do that.
Aaron Z
   / Log Splitter - How often tot change fluid and filter? #30
I don;t "pump" the handle. The governor should kick in when the motor starts to bog down.
2006 FONTAINE TH55 SERIES 102" X 42' LOWBOY TRAILE (A51243)
2006 FONTAINE TH55...
2015 CIMC 40FT CONTAINER CHASSIS (A52141)
2015 CIMC 40FT...
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
John Deere Disk Chisel (A50515)
John Deere Disk...
UNUSED FUTURE MINI SKID STEER TRENCHER (A51244)
UNUSED FUTURE MINI...
